Old 01-04-2013, 03:39 PM   #1
LSJUNIPER
Default FLathead shop
Hello, Does anyone know of a shop in CT that does work on Flathead motors? I have a block that is ready to be hot tanked and checked for cracks. Thanks.
LSJUNIPER is offline   Reply With Quote
Old 01-04-2013, 04:17 PM   #2
ford3
Default Re: FLathead shop
not near you so i cant send you to one, but any engine shop can hot tank and check the block for leaks, these engines are not rocket motors, the hardest part of the rebuild is butt grinding the valves to set the clearance, but you can(heaven forbid) use adjustables for that, its a cast iron block and machined like any other block, leave a message for ken ct on here, start a new thread saying ATTENTION KEN CT he lives in ct and does the carbs for flatheads, i know he will be able to send you to some one close, tell him what you need
ford3 is offline   Reply With Quote
Old 01-04-2013, 05:11 PM   #3
ken ct
Call me i need more info!! ken ct. 1-203-260-5945 cell
ken ct is offline   Reply With Quote
Old 01-05-2013, 05:33 AM   #4
51 MERC-CT
51 MERC-CT's Avatar
Here are two to check out.
Ezold's Model A Garage
1120 Southampton Rd
Westfield, MA 01085
(413) 562-0273
http://www.eastwoodsautomachine.com/index.html
Old 01-05-2013, 10:29 AM   #5
42panel
42panel's Avatar
I've worked with Eastwoods Auto Machine in Somersville CT and they do excellent work.
42panel is offline   Reply With Quote
Old 01-31-2013, 11:29 AM   #6
LSJUNIPER
Dropped of the block, crank, cam and rods at Eastwoods Auto Machine last Friday.
Old 01-31-2013, 12:33 PM   #7
GOSFAST
GOSFAST's Avatar
Whatever shops you guys deal with make certain they have the ability to pressure-test these castings, magnafluxing is NOT a 100% guaranty that the integrity hasn't been sacrificed.
It doesn't hurt to do both, but the pressure-test is first!
Thanks, Gary in N.Y.
P.S. All the most recent 8BA type blocks we've done here have come up good! Just the usual 2 cracks at the head bolt holes! These are non-issues.
GOSFAST is offline   Reply With Quote
Old 01-31-2013, 12:55 PM   #8
GreenMonster48
GreenMonster48's Avatar
Eastwood is a little pricey but do great work. Earl's Engine up in Stafford is working mine.
Eastwood just did a '56 International Black Diamond 6 for my friend. They def know what they're doing.
GreenMonster48 is offline   Reply With Quote
Old 02-01-2013, 06:05 AM   #9
LSJUNIPER
Yep, Eastwoods does pressure testing. Going to have the motor magnafluxed as well.
I hope its a good block. If not I didn't pay a lot for it.
