07-02-2016, 02:41 PM | #1 |
Does anyone have any info on these two items?
Hi Guys,
I found this wrench under my rear seat, it was frozen solid with rust and i soaked it for 4 days in white vinegar and water and presto 98% of the rust was gone. It had no handle but the rivet was there so I assumed it had been wood(I have been wrong before); so i carved a handle to fit out of an old rake handle. Anyone know anything about this wrench? It says "made in warrand" on the top side, as far as i can make out. The second item came from the rear fender when i took it off. I know it's the welting but i've never seen any with those little hooks on it and a wire bead. Is that original welting? thanks. |
07-02-2016, 09:43 PM | #2 |
Re: Does anyone have any info on these two items?
If no success here on the wrench try : http://alloy-artifacts.org/
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 07-02-2016 at 09:43 PM. Reason: additional wording |
07-03-2016, 12:17 PM | #3 |
looks like an early(late 20s-early 30s) Fulton adjustable wrench
Hotrods don't have valve covers |
07-03-2016, 12:51 PM | #4 |
Thanks Silver sink,
That's what it is ok.."Bemis & Call H& T Co." Springfield , Mass. I should have know that I lived 20 miles from there for 32 years...duh. Michael... |
07-03-2016, 03:26 PM | #5 |
Were these wrenches also called "Monkey Wrenches" ?
07-03-2016, 03:47 PM | #6 |
07-04-2016, 10:55 AM | #7 |
The term "monkey wrench" dates back to 1807 in Great Britain. Referring to the tool, the phrase appears in E.S. Dane’s "Peter Stubs & Lancashire Hand Tool Industry" catalog, which reads "Fleetwood, Richard...Parr, Rainford. Screw plates, lathes, clock engines...monkey wrenches, taps."
In 1858, Charles Moncky of Baltimore, Maryland, applied for a patent for the monkey wrench. Some believe the term monkey wrench is a derivation of Mr. Moncky's name, but its use in Great Britain in 1807 negates this assumption. The phrase "throwing a monkey wrench," meaning the creation of an obstacle, dates to a 1907 article in the Chicago Tribune, which reads: "It should look to them as if he were throwing a monkeywrench..." |
07-04-2016, 07:58 PM | #8 |
I have 4 of these different sizes, see them a lot at flea markets. Don't know much about them...
