05-06-2016, 09:17 PM | #1 |
Another question from the uninformed---me
I'll try to sum it up briefly; my car didn't run when i got (after being promised it did) when I took the head off and it had water in 3&4 cylinders..duh.. no wonder it wouldn't start.. I got a new head , new head gasket, replace #1 exhaust valve(it had a burnt crack in it). Put it back together and still no start. I 've timed it 20 times (at least), I take the head off again and see that the when the timing pin falls into the dimple, the #1 piston is already 1 1/4" on the way down.
When I took the valve cover off I may have picked up the oil pump gear to look at it. it's Been 6 weeks since i did that so i don't remember if i moved it. Question: is there such a thing as putting that gear back in so that it would throw off the timing?? If so how it that corrected?(with just turning the rotor until it lines up with #1 in the dist. again. AND, it has no compression in #1&2 cyl. Thanks guys...you knowledge is astounding! Michael... P.S. this is an engine that has sat for 50 years in a barn, but engine spins readily. |
05-06-2016, 09:36 PM | #2 | |
Re: Another question from the uninformed---me
Now for the no compression in 1&2. Are the valves opening and closing? I think you should be able to see by removing the side plate. Charlie Stephens |
05-06-2016, 09:46 PM | #3 |
Thanks Charlie for the reply, no it doesn't look rebuilt, my friend suggested that I lap all the valves first and then try the compression, if there is none then take out the pistons and do new rings... ahh if only i had a garage..hahaha
05-06-2016, 10:52 PM | #4 |
I agree with Charlie.
You first have to be sure the timing gear marks are aligned. Then with the pin in the dimple, #1 piston should be at Top Dead Center. I would verify and correct as necessary before I would go any further. Then as Charlie said, look at the valves on #1 & #2 cylinders to be sure they completely close. Valve lash, valves not fully seating etc. With these two things verified and corrected, then you should have compression on all cylinders and with the ignition timing set correctly, the engine should run. I would not pull the pistons quite yet. See how it runs first than decide if it is necessary to pull the pistons. My opinion, Chris W. |
05-06-2016, 11:26 PM | #5 |
Where in Florida are you?
05-06-2016, 11:27 PM | #6 |
And, FWIW: Sounds like you would benefit a lot from obtaining a friendly visit from a local, mechanical Model A Club member, if one in your area; and whether yes or no, reading a Les Andrews Model A Mechanics Handbook, Volume I .... would never hurt ..... even if you already have mechanic experience in other areas. |
05-06-2016, 11:36 PM | #7 | |
05-06-2016, 11:54 PM | #8 |
Maybe his cam gear (fiber type) is coming apart from the center?
05-07-2016, 12:09 AM | #9 |
How about a picture of your distributer to be sure it is Model A and a picture of the boss on the timing cover where the timing pin screws in? Hold off on lapping the valves and pulling the pistons for a ring job as my guess is that there is another problem. My guess would be rust keeping the valves open. Pull off the side plate and see if the lifters are functioning when you turn the engine over with a hand crank. Pull off the timing cover and be sure the timing gear is not coming apart as Art said and also that the dimples are aligned on the crank gear and the timing gear. Where did you go for instructions on how to time it? I assume it is in the Service Bulletins or you can use http://www.abarnyard.com/workshop/timing.htm. Post the name of the person that sold you the engine to protect the rest of us.
Charlie Stephens Last edited by Charlie Stephens; 05-07-2016 at 12:22 AM. |
05-07-2016, 08:02 AM | #10 |
Hi Mike V. I'm in central FL. between Ocala and Leesburg just out side the Villages.
05-07-2016, 08:09 AM | #11 |
Hi H.L. yes i am familiar with Les. i have both his books here and have watched his videos.
There is a local club here and i will contact someone. I just finished putting together a 1930 PU for a member of the club, and this is the 4th A i have built but I never had any engine problems before, so i'm completely in the dark there. |
05-07-2016, 10:13 AM | #12 |
1. From your above report in Reply 11, no doubt you will succeed.
2. Fifty years of sitting in a barn depends a lot on the type of barn; but, in thinking positively, at least your engine is about the same age as all of the other engines mentioned on this Forum. LOL. 3. It is very possible that you have original valve tappets which are moved up and down by the cam; hence, if you installed a new, non-adjusted no.1 valve, it is very possible that this valve is not closing tightly to seal the no. 1 combustion chamber. 4. When one grinds valve seats, metal is removed from the valve seat area; hence the required valve stem gap near the tappet is reduced to where metal has to be "very carefully" removed from the end of the valve stem until one obtains a gap of 0.011" at the ends of intake valves, and 0.013" for exhaust valves. 5. Providing such small miniscule valve stem gaps with the original tappets is never mentioned often, but is not a big deal. After doing about (2) valves, it is about as easy as rolling (8) cigarettes with a pack of tobacco and a book of cigarette paper. Let me know if you would like to hear how this was easily done often years ago with simple non-electric hand tools ....... in the 1930's rural electrification had not happened everywhere yet ..... kerosene lamps, chamber pots, and wood stoves were considered Uptown ...... but the Model T's and Model A's kept rolling with vintage rural mechanical ingenuity. Last edited by H. L. Chauvin; 05-07-2016 at 10:16 AM. Reason: typo |
05-07-2016, 10:23 AM | #13 |
here are some pics i just took..i'm pretty sure it all Model A parts.
5frontengine.jpg 5topengine.jpg 5sideengine.jpg 3112016water in cylinders.jpg |
05-07-2016, 10:30 AM | #14 |
Hi Charlie, pics have been posted... yes i have seen that timing article by Marco several time..I think i have it memorized..lol I just finished puttiing that front timing cover bacj on..not looking forward to taking it off again...
By the way where or what is the alignment mark on the crank gear? I have two extra blocks in the spare parts i recieved but they are way beyond repair. one has both front gears on it and i don't see any mark on the crank gear, maybe i don't know what i'm looking for? |
05-07-2016, 11:08 AM | #15 |
If anyone would like to email me or phone me it's ok.
[email protected] or 352-483-6901. I'll be out in the tent for a few more hours...lmao |
05-07-2016, 11:26 AM | #16 |
The timing cover has just been off and reinstalled ?
Both timing gears are marked and need to be aligned. The crank gear with have a dimple just to the right side of the key. The cam gear will have a corresponding dimple between the teeth which needs to be installed aligned with the dimple in the crank gear. This may be hard to see because the slinger gets in the way. When aligned correctly, when the timing pin is inserted in its hole it will drop into the cam gear dimple at TDC [ top dead center] [ when the piston is at the top of the bore]. |
05-07-2016, 11:57 AM | #17 | |
Charlie Stephens Last edited by Charlie Stephens; 05-07-2016 at 12:03 PM. |
05-07-2016, 11:58 AM | #18 |
Hi Patrick...ok thank you , i'll look again.. Yes i took the cover off to make the fiber gear dimple more pronounced so i could find it with the pin. It wasn't even dropping in before.
05-07-2016, 11:59 AM | #19 |
ok charles....thank you..lmao no wonder i din't see it... OMG.
05-07-2016, 12:12 PM | #20 | |
Charlie Stephens |
