Old 10-31-2020, 07:57 PM   #1
rfitzpatrick
Default Horn
I'll get the horn working and after the couple months driving around Town--
it slowly will only chirp. Do they require that much attention, or what.
It's not a Model A if the horn don't work right -- and yes, it's been rebuilted/oiled.
rfitzpatrick is online now   Reply With Quote
Old 10-31-2020, 10:03 PM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Horn
Your generator needs to be charging to get a good horn sound. Otherwise, loosen the adjuster screw one or two clicks on the back of your horn and see if that helps.
Mike Peters is offline   Reply With Quote
Old 11-01-2020, 06:10 AM   #3
Werner
Werner's Avatar
Default Re: Horn
Guten Morgen,
it is also important that the copper collector and the motor brushes are free of grease and smooth.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 11-01-2020, 06:11 AM   #4
30ccpickup
30ccpickup's Avatar
Default Re: Horn
I use sewing machine oil to oil my horn. The outside temperature plays a part in the horn efficiency. If I know I'm going to be using it: I back off the screw, press the button and spin the motor to warm up and thin the oil. I then retune it by adjusting the screw.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 11-01-2020, 06:18 AM   #5
aermotor
Default Re: Horn
My horn has stopped working, all of the above suggestions have been accomplished. In the dark I noticed occasional small sparks behind the horn button when pushed and a slight sound from the horn. Suggestions?
John
aermotor is offline   Reply With Quote
Old 11-01-2020, 11:24 AM   #6
Badpuppy
Default Re: Horn
John
Check condition of brushes and springs, may not be making good contact. Sparking you describe is normal without a horn relay.
Old 11-03-2020, 05:46 PM   #7
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Re: Horn
If you mean, by horn button, the button in the middle of the steering wheel, sounds like it’s rusty, or corroded underneath there. I have just held the horn button down, and rotated it with the palm of my hand to try and clean it, which helped. I am not sure how you could see sparks from there though?
Old 11-03-2020, 06:52 PM   #8
JohnB15632
JohnB15632's Avatar
Default Re: Horn
On my A, I added a ground wire for all six of the lights, the horn, and finally the engine to the frame. Grounds or lack there of, can be real gremlins.
JohnB15632 is offline   Reply With Quote
Old 11-03-2020, 08:45 PM   #9
Chuck Sea/Tac
Default Re: Horn
The horn button is the grd. What did you change?
