Old 03-10-2016, 06:20 AM   #1
LSJUNIPER
Default Missing Wire
I think I need some help here. I think I am missing a wire on the distributor see picture... I took a look at other motor pics on line and they all had a wire from the distributor to the junction box on the fire wall...
Did all model A's have this wire??
Thanks
LSJUNIPER is offline   Reply With Quote
Old 03-10-2016, 06:27 AM   #2
Sunnybrook Farm
Sunnybrook Farm's Avatar
Default Re: Missing Wire
Only the ones that run.
Sunnybrook Farm is offline   Reply With Quote
Old 03-10-2016, 06:43 AM   #3
goodoldvic
goodoldvic's Avatar
Looks like the condenser(arrow) is missing or you have a modern type on the upper plate. You do need to supply voltage to the points and your picture doesn't show that.
goodoldvic is offline   Reply With Quote
Old 03-10-2016, 07:00 AM   #4
Big hammer
There are two openings in the base of the distributor, one for the condenser and one for the armored ignition wire. Also your distributor is 180 degrees out!
Old 03-10-2016, 07:29 AM   #5
James Rogers
James Rogers's Avatar
There are 3 openings, one for the armored cable, one for the condenser and, the one for the condenser screw (arrow). The distributor is not out 180.
James Rogers is offline   Reply With Quote
Old 03-10-2016, 09:27 AM   #6
roblesterjr04
Yes. I believe your missing wire completes the circuit for the ignition system.
-Rob
1929 Fordor Leatherback
roblesterjr04 is offline   Reply With Quote
Old 03-10-2016, 09:29 AM   #7
roblesterjr04
Based on the diagram I posted, it looks like you're missing the armored cable running between the dizzy and your ignition key... rather important fellow there.
-Rob
Old 03-10-2016, 09:55 AM   #8
james hitchcock
james hitchcock's Avatar
Actually the arrow is pointing to the screw access for the condenser. The hole on the right of the dizzy strap is for the armored cable.
james hitchcock is offline   Reply With Quote
Old 03-10-2016, 09:57 AM   #9
1955cj5
1955cj5's Avatar
Mine is an aftermarket replacement, but you can get the idea.
The other end connects to the ignition switch as shown in the diagram.
It routes power through the points. It is necessary...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 03-10-2016, 11:48 AM   #10
LSJUNIPER
Thank you all for the help!!!
Old 03-10-2016, 11:51 AM   #11
Mitch//pa
The suppliers show the exploded view on the distributor if that helps
