08-16-2020, 02:20 PM | #21 |
Re: The Ugly Green Thing ('35 Panel Delivery)
I have been delinquent in doing anything on the panel for sometime until last month. I managed to put new head gaskets in and now have the engine in the frame and much is hooked up. While waiting for some parts I ordered I tore my starter switch apart as it was frozen with Rust. I know new ones are available but I enjoy some tasks just for the challenge and satisfaction.
Drilling the plunger to get things apart, I ground it off, drilled it and made a new end post for it. I stretched an extension spring to make a new compression spring. It is a bit stiffer but will work. The cardboard insulation was shot so I used some hard rubber. All the copper parts were still good. The last photo shows how I compressed the spring for assembly and re-riveting. The 4 corner tabs were heated to relieve stress and then bent over. Finally I painted it with silver Rust-Oleum and let the sun bake it at 80 degrees or so. It kept me out of mischief for 4 days and now the other parts are here. I hope to have further progress to report soon. Rich |
08-16-2020, 04:30 PM | #22 |
While I'm at it I have questions about three holes in the intake manifold. I'm guessing the threaded one might be for a vacuum wiper. The other two don't seem to go to threads. Are these for manifold bolts and stripped or something else? I have been an amature mechanic for 55 years but haven't worked on Early V-8's that much
Thanks Rich |
08-16-2020, 05:11 PM | #23 |
Great project, good luck with it and thanks for sharing.
08-16-2020, 08:57 PM | #24 | |
Hey Rich....The two blank holes closest to opposite ends of the manifold are 'locating' holes which fit over two raised pins which protrude out of some, but not all flathead block intake surfaces. If you look carefully, you can see that front pin sticking-up out of the upper, flat surface of the block pictured. There is another pin sticking up out of that same surface toward the rear, and on the opposite side of block. That threaded hole just about 3" farther forward is a vacuum source that is generally used for windshield wipers. There is a similar, threaded vacuum hole farther forward on the same side of the manifold. Your picture shows IT to already have a brass fitting threaded into it with a vacuum tube heading forward toward a distributor connection. DD |
08-16-2020, 09:08 PM | #25 | |
08-16-2020, 09:36 PM | #26 |
08-17-2020, 03:43 AM | #27 |
Since you re-posted the pictures of my truck, you might like to see it complete with lettering and striping.
08-17-2020, 09:00 AM | #28 |
Don, thanks for posting the pictures of your panel truck with the lettering, it is beautiful.
08-17-2020, 09:26 AM | #29 |
08-17-2020, 06:16 PM | #30 |
Wow! Looking good.
Thanks so much V8COOPMAN. That's exactly what I needed to know. Rich |
08-18-2020, 06:45 AM | #31 |
08-18-2020, 08:08 AM | #32 |
Beautiful truck!
08-18-2020, 02:29 PM | #33 | |
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 08-18-2020 at 02:35 PM. |
08-18-2020, 04:45 PM | #34 |
As for the ugly green thing, I put a battery in it and tested the new switch. Not only does it work but after pouring a little gas down the throats the engine fired. I guess you all know that thrill.
Rich |
08-18-2020, 05:30 PM | #35 |
That really is a nice looking rig Don!
08-18-2020, 08:29 PM | #36 |
Great to hear of your progress, what a thrill that is when they start for the first time in how many years?
08-19-2020, 07:06 PM | #37 |
Well, I've had the vehicle for about 50 years but didn't have a workable motor until a Street Rodder friend gave me one he took out of a running '36 so he could put something more modern in. That would have been a dozen years ago. I have enjoyed having it and have used it for props for photos and this painting which I used for a Christmas card several years ago. I called it "Birds of a Fender" or "Fenderbirds". Today I started going through a pile of carburetors I picked up over the years.
08-19-2020, 08:00 PM | #38 |
Max, that is a very beautiful painting! Dangit, we have some amazing talent on this site! I have a '47 panel, but it's just a beater compared to the two seen on this thread! Keep at it.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
08-20-2020, 08:59 AM | #39 |
All I can say is.... WOW
Love it! |
08-20-2020, 11:00 AM | #40 |
Thanks. As for beaters, this is and will remain one. I had visions of making it as nice as Don's but that won't happen. The panel was rolled in the 40s. The frame was badly bent so I will mount it on the good frame I have. The doors still open and close but it will be an ongoing project to straighten many areas. It is covered with a collage of colors from various paint jobs. Since I have some presentable restored cars I am now trying to build ones that look like barn finds but are mechanically sound. There are many ways to enjoy these.
