12-10-2016, 05:15 AM | #1 |
packing body blocks 28-9 roadster p/u
Hi folks, at this stage i am setting up the body blocks on my 28 roadster p/u.
It says that on the chassie side of the wooden body block there is a rubber pad,now i have done that on body block 3 and 4.The question is dose a rubber pad go on the front body block 1 .2.3.This is for a steel sub frame.The front body block is all one block for 1.2.3..In the front section there is not much room to put a rubber pad, as it slides in between two metal brackets. Hope someone can help me out , Many thanks Gerry (NZ) |
12-10-2016, 08:35 AM | #2 |
Re: packing body blocks 28-9 roadster p/u
The long rubber pad goes under the metal cowl, not inside the opening where the wood piece goes. It lays on the front part of the splash apron.
Rusty Nelson |
12-10-2016, 02:01 PM | #3 |
Hi many thanks for your reply,i was scratching my head there as to where it would go.once again thankyou. Cheers Gerry(NZ)
12-10-2016, 02:14 PM | #4 |
Gerry,
In addition to what Rusty said the front wooden block was originally painted body color and the others had some black paint to serve as a preservative. Dave |
12-10-2016, 04:43 PM | #5 |
