06-03-2016, 02:33 PM | #21 |
Re: Coil.coil.coil !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
06-03-2016, 04:33 PM | #22 |
GM...Did I miss something?...How can you run a Skip rebuilt stock coil on an electronic distributor....
06-04-2016, 09:05 AM | #23 | |
perfect with the original parts if set up on a Ford machine. Skip made some special coils for the guy in Ca. before he closed down. They had an extra wire to supply voltage to the electronics. G.M.
www.fordcollector.com |
06-04-2016, 10:40 AM | #24 |
I have 2 of Skip's coils on 12 volts with Pertronix ignitions. No extra wire. No problems
06-05-2016, 05:20 AM | #25 | |
1933 Ford V/8 Flathead Rebuilt and Balanced. +.20 over bore Mercury 4” stroke crank - (240 cu. In.) Isky “400” lift cam w/ adjustable lifters. 258 Duration part # 214000 Original Eddie Myer heads and intake w/two 97 carbs. Headers / dual exhaust
A man should do what he thinks best! "The Duke" |
06-12-2016, 09:28 AM | #26 |
