06-25-2015, 07:59 AM | #1 |
Fan questons
i am thinking of putting an 8 blade (8 bolt) 8ba fan on my 4 blade 59ab pulley. does this work #1 ? is it a pie in the sky idea, me thinking it will pull more air ?? or will it just drag the engine down ? looks like it would clear all hoses etc. I am sure someone has tried it. any suggestions.
thank you |
06-25-2015, 08:17 AM | #2 |
Re: Fan questons
What year? A lot of ideas here if it's a heating problem you are trying to solve / Most won't ROB Hp from you.
06-25-2015, 06:26 PM | #3 |
Re: Fan questons
1947 ford 59ab really no heating issues even at 111 degrees here in AZ, just nothing to do in my head so I think up these silly ideas. I have an 8 blade fan sitting around and thought it might add something (in function and looks) but it also might drag making the engine work harder.
thanks |
06-25-2015, 06:30 PM | #4 |
Re: Fan questons
I have learned the hard way...Don't fix it if it "ain't" broke!
06-25-2015, 09:05 PM | #5 |
Re: Fan questons
06-25-2015, 10:48 PM | #6 |
Re: Fan questons
06-26-2015, 12:23 AM | #7 |
Re: Fan questons
eight bladed fans were made for stationary engines, generators water pumps, winches, they were needed because air wasn't forced thru the rad with a moving car, leave the car alone
06-26-2015, 05:24 PM | #8 |
Re: Fan questons
I JUST PUT IT BACK ON THE SHELF. On to the next hair brained project !!!!
thanks people |
06-27-2015, 11:11 AM | #9 |
Re: Fan questons
Also most stationary setups pushed the air through the rad (why blow hot air over the hot motor) so they are impractical for auto use.
06-27-2015, 11:24 AM | #10 |
Re: Fan questons
Stock 6 blade fan common to F-1 pickup
Have seen 4 blade too using the same hub.
Tim Downtown, Ca |
06-27-2015, 11:27 AM | #11 |
Re: Fan questons
This aluminum hub offered for alternators uses the early bolt on fan blades. Will it fit a generator?
Tim Downtown, Ca |
06-27-2015, 05:42 PM | #12 |
Re: Fan questons
Won't that put the fan too high to actually pull air through the radiator?
