10-10-2013, 07:15 PM | #1 |
Wishbone alignment
Another newbe, I bought a 1930 A pickup a few months ago. It has given me great fun and a good deal of frustration. I've wanted a Model A since I drove a friends in high school in the mid 60's. I saw this truck and just couldn't resist, so I blindly jumped in with both feet.
I drove semi's for work so the trans wasn't a problem, and the brakes weren't to scary but the death wobble was an eye opener. The spark advance, and GAV were a bit mystifying. The previous owner had passed away so the truck sat for a few years, But I got it going and drove it before I bought it. The death wobble didn't happen on the test drive so it was a scary, disappointing event on the drive home. With some research including this Forum (Thank You) I was able to eliminate the problem. King pins, new steering arm balls, rebuilt drag link/tie rod ends, spring perches, and a shortened pitman arm. A little toe in and presto no more wobble. So, here's my problem, after all of this work I had difficulty bolting up the ball on the wishbone. It is about 1/2~3/4" aft of the socket. I used a couple of nylon straps off of the front bumper brackets to pull the ball in alignment. I don't think this is right and there might be some issue with the front springs. I have not seen any posts about this. Is this normal? Now all I need is to be able to drive down the road and not move the steering wheel like I'm in some 30's movie. I have found someone to rebuild the box so that issue is hopefully addressed. There is the issue of the leaking water pump throwing water and grease in the engine compartment. I tried greasing and tightening the seal but I still had a leak. I bought a leak less pump. I removed the radiator and saw a leak from a crack in the water jacket above the timing gear housing. Great so now I pull the motor. I thought I would split it at the bell housing no problem until mounts were so tight I had to pry the motor out of the frame (I think this is to be expected) but now I thinking that to put the motor back I am going to have problems lining up the trans and mounts and prying the motor back in place. So I remove the trans thinking aligning a u-joint has to be easier. Now here's an issue the u-joint housing has an internal cup that comes off with the housing. This cup has many small flat spots or dents and I think it should be smooth. Is this normal? Is this a problem? Thanks for any thoughts, opinions Herb |
10-10-2013, 08:33 PM | #2 |
Re: Wishbone alignment
Your wishbone problem is common. I usually have to loosen the front spring u-bolts and wiggle things around when this situation arises, then use a jack to raise up the ball end, and it will snap into place. Not a biggie. Enjoy your truck. It looks like a beauty!
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. Last edited by 700rpm; 10-11-2013 at 12:05 AM. |
10-10-2013, 08:47 PM | #3 |
Welcome!
I'm sure you will enjoy your Pickup as I have mine. You will probably want to get a copy of the Les Andrews book(s) and the Service Bulletins. They will become your BFF, as will this forum. A frame spreader or some other device to "gently" spread the frame at the rear motor mounts will make putting your engine back in place a piece of cake. Be sure to look up (and join) a local Model A club. There are several near you there in Washington.
10-10-2013, 09:19 PM | #4 |
Welcome, nice truck. Agree on Les Andrews Book and the Service Bullitens, guaranteed ROI on the buy, Can you pist a picture of the U Joint Cup?
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain. It is the very things that we think we know, that keep us from learning what we should know.- Unknown |
10-10-2013, 10:02 PM | #5 |
Where are the dents on the inner cup?
If they are on the inside, they were caused by a U-joint hitting it, and not a problem If they are on the outside of the cup, then you want to make them smooth, as the cup needs to move smoothly within the outer shell, and it's lubed by the grease and gear oil. When you assemble the inner cup don't forget the 2 gaskets, one on each side of the mounting flange. |
10-11-2013, 12:36 AM | #6 |
10-11-2013, 09:56 AM | #7 |
Yes I did
10-11-2013, 10:54 AM | #8 |
Ray.... Thanks for the info. I don't mind bending and pushing things into place as long as it considered a common practice.
Carl.... Thanks I have only had it a short while and am really having fun with it I just hope the wallet holds out. I have Vol. 1 Les Andrews and this forum has been a most informative and entertaining resource yet. I'll check into the service bulletins. I saw the frame spreader but buying tools that I hope to use once or twice is a cost I find hard to bare. Now maybe if I could turn it 90˚ and get another inch in the cab I would definitely get one. The local clubs are not that local for me, but I'll look into them. QGolden.... Thank you I'll try and post a pic Tom.... The tiny dents or flat spots are on the outside of the cup. The inside of the receiving cup on the torque tube does not seem to be as bad but I can't imagine why or how they happened. |
10-11-2013, 11:09 AM | #9 |
Does the inside of the bell on the front end of the torque tube have marks also?
I've seen some serious gouge marks on the bell and cup parts. I can only imagine it was bounced around over rough roads and completely void of any lubrication. |
10-11-2013, 11:44 AM | #10 |
QGolden....I think this should work for a pic
http://img196.imageshack.us/img196/7066/kayh.jpg |
10-11-2013, 11:46 AM | #11 |
I'd like to get another 6 inches in the cab, but that's a whole 'nuther story. My wife says that since the truck won't enlarge itself, that the occupant needs to shrink. What a gal!
10-11-2013, 11:56 AM | #12 | |
Darryl in Frozen Fairbanks |
10-11-2013, 02:44 PM | #13 |
Hster: Do you have a larger picture?? That appears to just be wear due to a lack of lubrication, I wouldn't get too excited. JMO
Try a search as where/if you're leaking is a common one and can be addressed (usually) with a Dremel and some JB weld. Are you near a tool rental place or friendly with a garage or body shop where you could rent/borrow a portapower ram to spread the frame?? WELCOME ! ! ! ! Nice truck. Paul in CT |
10-11-2013, 02:47 PM | #14 |
"Ray.... Thanks for the info. I don't mind bending and pushing things into place as long as it considered a common practice."
Just to clarify, I am not recommending bending anything. Just loosen things up so there is some movement option.
10-11-2013, 04:57 PM | #15 |
I got ya. Just a stretch or spread.
10-11-2013, 05:00 PM | #16 |
10-11-2013, 05:26 PM | #17 |
I have, am buying a rebuilt motor the previous owner did the JB Weld thing. That's not the kind of fix I want. My hope is the "new" motor will resolve other issues... blow by... Babbeted bearings with a 4.11 rear end, leaking head gasket, leaking rear main seal. I realize it all works OK but I just can't seem to leave it like this.
10-11-2013, 05:53 PM | #18 | |
I have not figured this photo post thing yet so let me try. The fellow that is building me a motor said it is a fairly common leak and it can be repaired. I think he said it could be brazed which means I'd need to pull it or try to braze it myself. There are enough issues/concerns with this motor I'm just going to bite the bullet or rob a bank or pan handle and get a rebuild. The Portapower is a good idea I'm not sure about having a away to get it in place so it doesn't interfere with the trans. I'm afraid it's not such a nice truck now http://imageshack.us/photo/my-images/38/2lls.jpg/ but it will be! |
10-11-2013, 05:56 PM | #19 |
One more try for pics
http://imageshack.us/photo/my-images/580/uirt.jpg/ |
10-11-2013, 05:59 PM | #20 |
Hster
If you have a crack similar to the one shown on my Model B engine, I fixed it using 11 each 1/8" solid brass pipe plugs. I started on each end of the crack, drilled and tapped halfway into each plug and worked towards the middle, ground it near flush then center punched each plug. This was thirty years ago. I was scratching around on the block trying to find the repair to show someone so I took some photos of it at that time. I know that there are various ways of repairing cracks, I had read about this method in an old book and gave it a try. It was quick, easy, inexpensive and has lasted flawlessly. Good luck Darryl in Frozen Fairbanks Last edited by darrylkmc; 10-11-2013 at 07:19 PM. Reason: rewording |
Thread Tools | |
Display Modes | |
