04-17-2021, 08:59 AM | #1 |
ID aftermarket drums 21A/O1A-1125
I have set of aftermarket drums that I would like to identify the Mfg. and aprox age of them. The casting has MB on it along with the #41, and some other numbers. The box was marked 21A-1125. Photos. Thank you.
04-17-2021, 12:22 PM | #2 | |
Re: ID aftermarket drums 21A/O1A-1125
Of note though, Ford NORMALLY did not sell DRUMs ONLY across the counter. An "-1125" USUALLY means an "ASSEMBLY", as in hub/drum assembly! DD |
04-17-2021, 05:42 PM | #3 |
The Early V8 store and Joe's both sell the drums, with the 21A & 01A ones having a 3 1/4" id mounting hole where the hub fits under the drum. I also see Bolling Bros. drum that look similar.
04-17-2021, 06:04 PM | #4 | |
Any chance you could post a picture of the full drum? A pic of the inside would be a BONUS! Thanks...DD |
04-18-2021, 08:16 AM | #5 |
Here are more photos of the drums. #1 is the drum with a 01A-'40 front hub installed in it. #2 is the drum & hub. #3,4 & 5, Letters & numbers on casting. #6 inside the drum, #7 the box they came in. Thank you.
04-18-2021, 12:36 PM | #6 |
russcc .....I THINK that MAYBE I have found your drums...at least the source, anyway! C&G shows essentially the same drum except for the cast-in markings. Whatcha think? Below is a link to the C&G ad. It's the one on the TOP, RIGHT! DD https://cgfordparts.com/ufolder/cgca...&searchnumber= |
04-19-2021, 06:05 AM | #7 |
Thank you. Should we assume these are imported drums ? I will check with Joe and see what he says.
