Old 10-15-2019, 09:19 PM   #1
Don T
Don T's Avatar
Default 50 shoebox diff
Can someone confirm that the pinion setting is set by crush washer or is it set by shims in this diff. Thanks for the help.
Don T is offline   Reply With Quote
Old 10-16-2019, 07:50 AM   #2
Frank Miller
Frank Miller's Avatar
Default Re: 50 shoebox diff
I believe it is a crush washer or spacer.
if you're replacing a seal just mark the nut to the shaft for reference, If you did not do that then just tighten it and check bearing preload, which I usually do bt feel. Not loose but just some drag.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
