Old 09-14-2020, 08:13 PM   #1
steve fritz
Default 55 or 56 Ford y block ID ?
Did 56 Ford Y-blocks 272/292 originally have the frost plugs on the front of the heads ?
I thought that was an indicator of a 55 272 y-block.
steve fritz is offline   Reply With Quote
Old 09-14-2020, 08:36 PM   #2
darrell
Default Re: 55 or 56 Ford y block ID ?
they did for at least the first half of 56.dont know the month the change took place
darrell is offline   Reply With Quote
Old 09-14-2020, 08:58 PM   #3
dmsfrr
dmsfrr's Avatar
Core plugs in Y-block heads began in '54 and were discontinued sometime in the first part of the '56 model year.
The chart at this link doesn't indicate which heads had them and which didn't, but will help you ID them otherwise...
http://ford-y-block.com/cylinderheadchart.htm
Photo 2 - a '56 ECZ-C head, without core plugs. I'll assume heads alphabetically earlier would have had them, but I don't know where the break is.
Here's a link to an engine block casting number chart because, the same heads were used on different displacement engines...
http://ford-y-block.com/Block%20identification.htm
dmsfrr is offline   Reply With Quote
Old 09-15-2020, 05:08 AM   #4
darrell
i tried several times to find out where the break is but never did.anyone know
Old 09-15-2020, 07:45 PM   #5
Herman Munster
Herman Munster's Avatar
My 56 with a build date of 10/21/55, according to the patent plate, has the freeze plugs. It has the original 292.
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic
Herman Munster is offline   Reply With Quote
Old 09-15-2020, 07:50 PM   #6
paul2748
paul2748's Avatar
Both types of heads had the same casting (engineering ) number ECZ-C
48 Ford Conv
56 Tbird
54 Ford Victoria
paul2748 is online now   Reply With Quote
Old 09-15-2020, 08:09 PM   #7
dmsfrr
dmsfrr's Avatar
That's a pretty early one. Do you know the casting number on the heads?
Old 09-16-2020, 06:32 AM   #8
steve fritz
55Q is on the heads.
Old 09-16-2020, 08:49 AM   #9
Herman Munster
No, I have never checked.
Old 09-16-2020, 10:27 AM   #10
darrell
ted eaton is thinking early in 56.doesnt know if dif and cf heads changed at the same time.you would think with all the 56s out there with original motors it would be easy to narrow it down.
Old 09-16-2020, 11:21 AM   #11
55blacktie
Go to ford-y-block.com, scroll down, click on "Technical Info." , and then click on "Cylinder Head Identification."
55blacktie is offline   Reply With Quote
Old 09-16-2020, 12:45 PM   #12
darrell
55 Q would be may 17 55.those would be 55 heads.
Old 09-16-2020, 03:49 PM   #13
dmsfrr
dmsfrr's Avatar
steve fritz, The casting number on the heads should have a three letter prefix with the first two letters being: EC_
from this link... http://ford-y-block.com/cylinderheadchart.htm
