07-20-2020, 09:35 PM | #1 |
pressure brake light switch
ive blown at least 3 in the last 4 yrs
again tonight brake lights don't work swich is mounted on perportion valve on left inner fender |
07-20-2020, 09:59 PM | #2 |
Re: pressure brake light switch
Are you using Dot 3, 4 or 5 fluid ?
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
07-20-2020, 11:36 PM | #3 |
I've read that the Harley dealership will have a more modern switch that interchanges. Someone here will know the specifics.
07-21-2020, 07:27 AM | #4 |
dot 3
07-21-2020, 08:05 AM | #5 |
TBird suppliers (like Casco or Hills) offer a kit that replaces the pressure switch with a mechanical one. It operates off the brake pedal arm.
07-21-2020, 03:04 PM | #6 |
But the switches can malfuntion for other reasons too. i would put in a mechanical switch for more reliability. .
07-21-2020, 05:47 PM | #7 |
Don't buy anymore of those cheap chinese made brakelight switches. They are guaranteed to fail in short order. Both the seal inside and contacts are substandard. The cheat on everything.
I got a brakelight switch for my '55 from a motorcycle performance shop. It is set up to accept Dot 5 fluid, but I suppose you could still use Dot 3. It's been in there for years now and I get a lot of use out of it. You will need to do wiring terminal modifications to use the motorcycle switch, but it is the right pipe thread size and looks the same as the Dot 3 switch, except for the wiring. |
07-21-2020, 07:11 PM | #8 |
On my 54, I made a bracket that mounted on the firewall brace that the brake and clutch pedal are mounted to and installed a mechanical switch off ebay. Has worked great for the last 8 or 9 years. I have a write up on it if interested.
07-22-2020, 07:42 AM | #9 |
The Harley switch is the way to go. Mine has been in for nearly 15 years now with no sign of failure.
Bill, certified Ford nut. 2016 F-150 2016 Focus 08 Shelby GT500 57 Ford Ranchero 36 Chevy, 351C/FMX, 8", Mustang II |
07-22-2020, 06:52 PM | #10 |
i used Harley Davidson brake light switch #72023-51E. No more problems
07-23-2020, 09:03 AM | #11 |
they have a brake switch here in Ottawa at Harley dealership 72023-51E $27.
i'll try it thx if that don't work i'm going mechanical |
07-29-2020, 08:03 AM | #12 |
Painless Wiring makes one I've seen people use, it trips at low pressure. The one that came with my distribution block leaked immediately. The one from NAPA started out okay, but quickly took a lot of pressure for it to work. I now buy one on eBay that works fine, probably have 9000 miles on it. I carry a spare as well.
