Old 06-29-2020, 03:56 PM   #1
cvicky
cvicky's Avatar
Default starter or generator
my 55 Fairlane is converted to 12V and still generator
today it began cranking slowly when hot
when running it charging at about 13 and doesn't really change with lights on or when car is shut off
starters a couple years old reman
when the car is running and I take positive cable off car stalls
should a good generator keep car running without battery
??starter or generator
cvicky is offline   Reply With Quote
Old 06-29-2020, 06:47 PM   #2
darrell
Default Re: starter or generator
yes
darrell is offline   Reply With Quote
Old 06-29-2020, 06:52 PM   #3
dmsfrr
dmsfrr's Avatar
Measure the voltage across the battery terminals when the engine is off. Should be approx 12.5 to maybe 13 volts if the battery is fully charged.
Start the engine and with the rpm about 1500 measure the voltage on the battery terminals again. It should read around 14 to 14.5 if the charging system is working.
dmsfrr is offline   Reply With Quote
Old 06-29-2020, 07:18 PM   #4
cvicky
cvicky's Avatar
im 12.5 -13 all the time
should the car keep running when I disconnect positive
Old 06-29-2020, 11:21 PM   #5
Daves55Sedan
Daves55Sedan's Avatar
Yes
Daves55Sedan is offline   Reply With Quote
Old 06-29-2020, 11:23 PM   #6
Daves55Sedan
So....you converted it to 12Volts using a 1956 Ford generator and voltage regulator, right? Is the generator properly polarized?
Old 06-30-2020, 06:41 AM   #7
dmsfrr
dmsfrr's Avatar
The charging system in the car isn't working correctly.
How recently was it converted to 12 volts? Was it working right before and now it's not?
Here's the procedure for polarizing the generator.
It can be done anytime the need arises and only takes a minute...
before you start the engine, remove the Field wire from the voltage regulator and quickly touch it to the Battery terminal of the voltage regulator (you'll get a small spark). This will polarize the generator, then reconnect the Field wire to it's position on the voltage regulator.
Note: in this diagram the (red / + / positive) "Battery" labeled cables are connected to the starter solenoid on the large stud terminal on the right hand side.
In your vehicle those cables may be fastened to the large stud terminal on the left side instead, it does not affect the function of the system.
File Type: jpg Generator voltage regulator wiring c1.jpg (41.8 KB, 8 views)
Old 06-30-2020, 06:51 AM   #8
cvicky
cvicky's Avatar
got the car like that 4 yrs ago
ran great until yesterday
Old 06-30-2020, 07:28 AM   #9
bobss396
bobss396's Avatar
The best way to check a charging system is with it running and using a decent VAT tester. Sun used to make a nice one years ago. I like to check alternator/generator output not at the battery but between the UUT (unit under test) and the battery, this gives you the true output.
Hot weather is tough on electrics, be it the starter or charging device. How old is the starter, is it a 6V unit? When in doubt have it rebuilt if it is more than a few years old. I have a couple of auto-electric shops by me that are great.
Is the system 12V negative ground? That is always my preference on old cars. How old is the harness? Those were pretty simple but have no fuse panels, just fuse holders. I replaced the old crumbling harness on my '59, went alternator (63 amp) and high torque starter.
bobss396 is offline   Reply With Quote
Old 06-30-2020, 09:41 AM   #10
darrell
your gen should be the problem.if your regulator is bad the car will run with the cable of.
Old 06-30-2020, 10:13 AM   #11
cvicky
cvicky's Avatar
starts great battery fully charged
13V off or running with head lights on no change
take off positive battery CAR STALLS
how do I know if its voltage regulator
book says adj Field arm greator
i'll do polorizing but I think its ok because car started great for four years
new starter 2 yrs ago
original wire harness
12v negative grd
Old 06-30-2020, 11:46 AM   #12
dmsfrr
dmsfrr's Avatar
The voltage regulator is a self-functioning electro-mechanical switch that tells the generator when to turn on or off.
There is a way to test them individually to see which one isn't doing its job... but I don't know what it is.
Old 06-30-2020, 06:42 PM   #13
cvicky
cvicky's Avatar
well it appears generators are not redly available no switches either,
now I know why every one switches to one wire altinater
where can I get a kit on a high school budget LOL
Old 06-30-2020, 07:09 PM   #14
51504bat
51504bat's Avatar
Quality Power in Yucaipa, CA
https://www.qualitypowerauto.com/cat...p?category=148
GM 1 wire alternator is 100 bucks more or less depending on the output you want. But you should be able to get one almost anywhere. Mounting bracket is 45 bucks. Never have used one for a Y Block but I've used several of their brackets and alternators on flatheads with no issues.
Concours in Carson City, NV lists a Y Block bracket assembly that looks more specific than the universal one Quality Power lists. Its a little more money but it appears to have everything needed to mount the 1 wire alternator. https://concoursparts.com/
Concours is having a 4th of July 10% off sale right now. Code is FJ20
51504bat is online now   Reply With Quote
Old 06-30-2020, 08:29 PM   #15
miker98038
miker98038's Avatar
You can find the regulator adjustment in the shop manual, or probably any old Motors manual. But the next thing I'd be looking at is the brushes in the generator. Changing them was one of the first things I was taught for electrical systems.
It been so long, I really don't remember anymore.
miker98038 is offline   Reply With Quote
Old 07-01-2020, 07:12 AM   #16
cvicky
cvicky's Avatar
how about wires switching from generator to altenator
I still have original 1955 harness with 56 12v generator
Old 07-01-2020, 08:32 AM   #17
darrell
its cheaper and easier just get a generator.
Old 07-01-2020, 10:33 AM   #18
wellcraft17
12 volt generator at rock auto is $46.00 + shipping. If you are getting 13v at the battery with the engine running I would adjust the regulator before going any further.
wellcraft17 is offline   Reply With Quote
Old 07-01-2020, 12:11 PM   #19
cvicky
cvicky's Avatar
I had to file the ARM points in regulator
not sure what the adj should be
ARM points wr also discoloured
Old 07-01-2020, 01:20 PM   #20
dmsfrr
dmsfrr's Avatar
If you decide you need the regulator a local auto parts store should have or be able to get one in a day or so.
Don't let them sell you the 6 volt part. '56 to middle 60's Fords can/may use the same 12v regulator.
