Old 05-25-2020, 05:31 PM   #1
tommyleea
Default y block fuel pump
The fuel pump started leaking on my 272 y block. I received the new fuel pump. It came with gasket, fittings, and a bolt with lockwasher. What is the one bolt and lockwasher used for, and why just one? I thought maybe it was for a chevy to hold the pump actuator rod, but why the lock washer? Just one of those things that I keep wondering about. Thanks.. Delphi MF0063
tommyleea is offline   Reply With Quote
Old 05-25-2020, 07:44 PM   #2
darrell
Default Re: y block fuel pump
they forgot the other one.
darrell is offline   Reply With Quote
Old 05-25-2020, 08:27 PM   #3
mobileparts
It is on the deck floor of the boat from China because it fell out of that cheesy Chineseum cardboard.....
Too bad you didn't call me for a U.S.A. ethanol gas compatible Fuel Pump.......
mobileparts is offline   Reply With Quote
Old 05-25-2020, 09:54 PM   #4
Daves55Sedan
Daves55Sedan's Avatar
The Y-block fuel pump requires two bolts with lockwashers and one mounting gasket. One of the bolts probably did not get inserted into the box before shipping.
Daves55Sedan is offline   Reply With Quote
Old 05-26-2020, 08:52 AM   #5
tommyleea
I was looking on Rockauto, and the picture they show of this pump, only shows the one bolt and lockwasher, but no explanation.
Old 05-26-2020, 10:09 AM   #6
darrell
in these days of restraint you cant expect 2 bolts.
Old 05-26-2020, 11:49 AM   #7
Ole Don
Ole Don's Avatar
I never saw a fuel pump come with new bolts.
Ole Don is offline   Reply With Quote
Old 05-26-2020, 02:35 PM   #8
tommyleea
I haven't either!
Old 05-26-2020, 10:53 PM   #9
Daves55Sedan
I got one for a 223 6-cyl and one for a 272Y-block that did include new bolts (both from a local auto parts store, but that was back in the early '90's (pre-NAFTA).
Thank you Mr. Trump for blowing up that piece of garbage that sent our manufacturing overseas. NOW, bring back our factories to good ole USA.
Old 05-27-2020, 05:29 AM   #10
LOWRIDER
LOWRIDER's Avatar
Originally Posted by tommyleea View Post
I haven't either!
Me 3
Dan Kingman Az. 86409
LOWRIDER is offline   Reply With Quote
Old 05-27-2020, 07:45 AM   #11
54vicky
54vicky's Avatar
that is so you question your ability to do the job with a single bolt.that is also known as flat rate 101
54vicky is offline   Reply With Quote
