05-11-2018, 02:00 PM | #1 |
Crab 42-48 vacuum seal
Deal of the day !!! Someone had a post the other day regarding the vacuum seal on the 42-48 crab distributor.
I didnt have the time to look but knew we had some somewhere and i found them.!! Getting the old seal out is the biggest problem, you can leave the old rivit in if ya want or take it out when you remove the seal.. I will send you two new seals at no charge if you will send me a self addressed envelope with postage on it Thats as good as it gets . Need more send more envelopes ?????? My friday special just for the barners !!!! |
05-11-2018, 02:25 PM | #2 |
Re: Crab 42-48 vacuum seal
Bubba comes through again!
05-11-2018, 04:57 PM | #3 |
I guess they will all be gone by the time my SSAE gets there from OZ.
05-11-2018, 06:53 PM | #4 |
I see you have an rubber "O" ring under the vacuum piston cap. Are you sending them out that way?
05-11-2018, 08:27 PM | #5 | |
Over the years we have used different seals here from paper to small orings. Interesting that over the years building hundreds of these crab distributors ( or any distributor ) we see things, talk to customers and make service changes as we go based on needs etc. Fit and finish , types of lube to assemble, brands of parts, paint, stainless screws , caps clips , leather for vac brakes etc.....I actually believe we finally have got the clearances correct as well.... Heres 5 i did yesterday , note the point plate is painted with a special "transtar" primer as well. And i still learn something every time i build them |
05-12-2018, 04:39 AM | #6 |
I think it's a masterpiece of design. Mart. |
05-12-2018, 08:16 AM | #7 | |
05-12-2018, 09:18 PM | #8 |
Bubba why were some alloy and others steel for the crab? Seem to be more steel ones down here in NZ. I have both. I got the ali one from a part supplier in the US way back
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
05-13-2018, 12:23 AM | #9 |
I've heard the military ones were iron.
05-13-2018, 01:11 AM | #10 |
What and where is the rivet that we can leave or discard?
05-13-2018, 05:35 AM | #11 |
The "rivet" is in the center of the vacuum seal, it retains the seal. If you look at Bubba's post #1 above the second and third photo show the brass rivet, the best.
05-13-2018, 10:09 AM | #12 | |
Never really found a answer for that , when we did the crab trade program a few years back in a effort to find cores. I traded a few hundred units and 2 out of 100 were cast. We cleaned them up and painted them black and kinda like the look. I now have a few here and there , there is some variation on the castings as well..... Would like to hear the real answer i guess..... |
05-13-2018, 05:02 PM | #13 |
I will check when I get home if our steel crabs over here have that.
05-13-2018, 07:30 PM | #14 |
Mine used to whistle a hi pitched tune. Then I greased the leather and tightened it up. As of 4 days ago it now hisses. The reason I know is because I have a soft line (silicone) at the intake going to the steel tube to dizzy, and if I remove it the silicone tube, It's quiet as a mouse. Something downstream of the intake is hissing pretty bad.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
05-14-2018, 04:31 AM | #15 |
I can't see a reason for a 0 ring there. The gasket does fine. No 0 rings on a carb base
just a gasket right, and there is more vac. going on at the carb than that skinny little vac dist. line. |
05-14-2018, 07:41 AM | #16 |
Jim:
Is this deal still active? Thanks again for all you do! Tim |
05-14-2018, 07:56 AM | #17 |
Bubba That is a very nice thing that you are doing for the barners. Jay |
05-14-2018, 08:38 AM | #18 | |
Yep..............wont stop for a while .... |
05-21-2018, 09:27 AM | #19 |
Just mailed the first 6 letters with seals, let me know when ya get them....got plenty for any that wants them.....
05-23-2018, 12:49 PM | #20 |
I had a cast iron one I sold about a year ago, it was the only one I had ever seen.
