Old 05-23-2018, 02:50 PM   #21
RalphM
RalphM's Avatar
Default Re: Crab 42-48 vacuum seal
Originally Posted by BUBBAS IGNITION View Post
Just mailed the first 6 letters with seals, let me know when ya get them....got plenty for any that wants them.....
I think I see mine in the pile
RalphM is offline   Reply With Quote
Old 05-23-2018, 05:29 PM   #22
Ian NZ
Ian NZ's Avatar
Originally Posted by Graeme / New Zealand View Post
Bubba why were some alloy and others steel for the crab? Seem to be more steel ones down here in NZ. I have both. I got the ali one from a part supplier in the US way back
GB
Aluminium crab distributors are very rare here in N.Z. cast iron ones with a bronze bush for vacuum advance piston which are the best for the least amount of wear, are the best type I have worked on are and very common here.
Ian NZ is offline   Reply With Quote
Old 04-15-2020, 01:27 AM   #23
46Fordor
Deal of the day !!! Someone had a post the other day regarding the vacuum seal on the 42-48 crab distributor.
I didnt have the time to look but knew we had some somewhere and i found them.!!
Getting the old seal out is the biggest problem, you can leave the old rivit in if ya want or take it out when you remove the seal..
I will send you two new seals at no charge if you will send me a self addressed envelope with postage on it Thats as good as it gets .
Need more send more envelopes ?????? My friday special just for the barners !!!!
Hi Bubba, most informative, any chance of getting a part number and size of this O Ring please, great posts you put up, thanks
46Fordor is offline   Reply With Quote
Old 04-15-2020, 08:19 AM   #24
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
The o-ring i use is square cut and is a left over from my fuel injection business , its a toyota injection seal . send me a envelope and i will send ya some ......
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 04-15-2020, 09:13 AM   #25
Charlie ny
Jim,
Happy to see you are still at it, you are mister double D.......
distributors and dialysis..........keep keepin' on.
Charlie ny
Old 04-16-2020, 01:58 AM   #26
46Fordor
Thank you Bubba, I appreciate your generosity and the knowledge you pass on in this and other forums. Wish you a speedy recovery.
Old 04-16-2020, 03:09 AM   #27
46Fordor
Following the comments of cast iron crab housings in this thread, I have one with a lug on either side, perhaps someone can identify it and the model it was used on, maybe industrial??? here are some images;
IMG_3959 3.jpg[/ATTACH][/ATTACH]
Old 04-24-2020, 01:10 PM   #28
swanwaco32
I used a easyout to get the rivet out. Is it normal to not be able to the piston to move with a hand vacuum pump? Seems like the piston for the brake should have a tighter seal in the bore? Thanks John
swanwaco32 is offline   Reply With Quote
Old 04-24-2020, 02:43 PM   #29
BUBBAS IGNITION
A hand vac pump would be tough based on pure volume we use a test benchg with vac pump .........the actuall seal never needed to be very good as the engine has good volume for the little piston size .......
[email protected]
Old 04-25-2020, 04:34 AM   #30
swanwaco32
Thanks Bubba..!!
