Old 03-29-2017, 04:04 PM   #1
namvetmike
Default Remove window regulator
How do I remove the driver's side window regulator on a 31 Model A Tudor?
Sent from my iPad using Tapatalk
namvetmike is offline   Reply With Quote
Old 03-29-2017, 04:38 PM   #2
Farrell In Vancouver
Farrell In Vancouver's Avatar
Default Re: Remove window regulator
First steps would be to remove the handles and door card to get access to the hardware securing the regulator to the door. Once that is done you do a little fooling around to detach it from the window track and pull it out of the door. You will need the window crank handy to change the position of the reg to wiggle it off the track. I usually have the window blocked up safe so it cannot fall onto my digits.
Farrell In Vancouver is offline   Reply With Quote
Old 03-29-2017, 06:03 PM   #3
wk2w
Would it be helpful to jam rubber wedges between the glass and the window frame to hold the glass?
wk2w is offline   Reply With Quote
Old 03-29-2017, 06:19 PM   #4
Mitch//pa
Or if the 3 screws come out easy enough on the top of the door just take the glass completly out
Old 03-30-2017, 08:08 AM   #5
Rex Perry
1. Remove the window crank, the door opener and the garnish molding.
2. Remove the door trim panel which is secured with spring clips around the edge of the panel.
3. Crank the window up about half way. Cut a piece of wood, with a notch at the top for the window, and sufficient length to reach the bottom inside of the door.
4. Insert the wood and bring the window down to rest in the notch.
5. Remove the three flat head screws (1/4-20) holding the regulator to the inside of the door panel. The regulator is now free to be removed.
6. It will take some playing to slide the regulator arm out of the window track. Take your time.
7. On the top of the door there is a close out panel secured with three short screws. Remove those screws and the panel and the window will slide up and out.
Good luck
Rex Perry is offline   Reply With Quote
Old 04-19-2017, 11:56 AM   #6
namvetmike
Good luck
Thanks to all for the great info!
Old 04-20-2017, 11:48 AM   #7
KGBnut
KGBnut's Avatar
If it is anything like a Coupe, the real trick (mentioned in the instructions above) is to not forget to put the window in the half-up position. I tried the first time with the window up all the way thinking it would be out of the way....wrong.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
