Old 06-24-2010, 11:48 AM   #1
Bubby Sharp in KY
Default multidisc clutch
Does anyone know if there is a return spring on the multi disc clutch pedal ? The one I am working on does not want to return all the way up and is allowing the forks to ride on the throwout bearing . Bubby Sharp in KY
Bubby Sharp in KY is offline   Reply With Quote
Old 06-24-2010, 11:50 AM   #2
Rich in Tucson
Rich in Tucson's Avatar
Default Re: multidisc clutch
Yes there was and the vendors sell one now which can be used with any clutch.
Rich in Tucson is offline   Reply With Quote
Old 06-24-2010, 01:19 PM   #3
Ron in Quincy
Ron in Quincy's Avatar
Bratton's is selling the Clutch Pedal Spring, Part No. 11390 . You will have to make the retaining pin which is longer and has a small hole on the end for a cotter key.
Ron
Ron in Quincy is offline   Reply With Quote
Old 06-24-2010, 01:32 PM   #4
Bubby Sharp in KY
Thanks Ron & Rich , Found on p 50 in Brattons A bit pricey but just what I need. Bubby Sharp in KY
Old 06-25-2010, 09:18 AM   #5
ld
Hello Buddy: I have a NOS A 7523 AR clutch return spring. $ 18.00 postpaid. Call toll free 1 888 282 2066 M-F 9 am to 5 pm with any questions. Little Dearborn Parts Mpls MN.
ld is offline   Reply With Quote
