Old 10-09-2020, 09:05 PM   #1
the human wrench
Default Top loader question
I currently have a "56 Fairlane with a 3 speed overdrive transmission. I want to replace it with a top loader 4 speed I have with the small input shaft. Am I correct in thinking it will bolt up to my bellhousing? The top loader has 8 mounting holes. I will be using it with Thunderbird bucket seats and a Hurst shifter.
Miracle Engine Rebuilders. "If it runs, it's a Miracle!"
the human wrench is offline   Reply With Quote
Old 10-09-2020, 09:50 PM   #2
55blacktie
Default Re: Top loader question
Maybe this will help:jalopyjournal.com/forum/threads/toploader-in-a-y-block.855710/
55blacktie is offline   Reply With Quote
Old 10-10-2020, 05:56 AM   #3
darrell
it will bolt up with some work.if its out of a small block 289 to 351 the input shaft will need 3/8 ground of of it will bottom out and lock your engine up.i put one in a 57 years ago. also the front bearing holder that centers your trans in the bell is to big.you have to turn it down a bit not much.small things an easy swap.
darrell is offline   Reply With Quote
Old 10-10-2020, 06:54 PM   #4
paul2748
paul2748's Avatar
Darrell is spot on. I did the swap in back of a 312. If your using bucket seats then the shifter location may not be a problem. With the right tailhousing, the standard bench seat is not a problem.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-12-2020, 06:47 AM   #5
the human wrench
Thanks, doesn't sound too complicated.
