Old 02-05-2018, 02:40 PM   #1
john in illinois
john in illinois's Avatar
Default gas washed cylinders and ring sealing
I have a rebuilt 276 59a with 74cc heads and 2 new 97's. At first start up it was very rich and smoked out the tailpipes. I drove it and tried to tune it. I finally found one carb was defective and Stromberg replaced it. By then a lot of raw gas had got in and oil was black.
I have driven it 1100 miles and it uses oil.The tailpipes have a coating of oil on the ends almost dripping out . The plugs have some oil fowling. Its runs flawlessly and does not smoke. Compression is 160-165 on all cylinders.
I am trying to decide if I should hone the cylinders and put in rings or if the oil rings might seat with more miles. I do not understand why it pumps oil out and yet has good compression. I do not understand why it does not smoke.
Any ideas would be appreciated.
John
john in illinois is offline   Reply With Quote
Old 02-05-2018, 02:50 PM   #2
Ol' Ron
Ol' Ron's Avatar
Default Re: gas washed cylinders and ring sealing
Doesn't sound like rings, Find a shop that can do a leak down test. Is oil coming out the tail pipes? any leaks? Yes a rich mixture or running with out a load can cause this, but that's very good compression for bad rings
Ol' Ron is online now   Reply With Quote
Old 02-05-2018, 03:06 PM   #3
Bulligen
Bulligen's Avatar
Hi John, Was wondering what type of crankcase breather do you have on it?
Bulligen is offline   Reply With Quote
Old 02-05-2018, 03:48 PM   #4
john in illinois
Ron I can do a leak down test.Oil is coming out tailpipes, and on the plugs.
Bulligen I have the standard 59 breather system' oil fill breather and pan outlet. I should probably check that it is all open.
Old 02-05-2018, 03:55 PM   #5
Jack E/NJ
Jack E/NJ's Avatar
>>>The tailpipes have a coating of oil on the ends almost dripping out . The plugs have some oil fowling. Its runs flawlessly and does not smoke. Compression is 160-165 on all cylinders.>>>
Seems like too much oil is somehow seeping in some exhaust valve chambers. Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 02-05-2018, 06:28 PM   #6
flatjack9
flatjack9's Avatar
How much oil are you using?
Old 02-05-2018, 07:26 PM   #7
Crankster
Crankster's Avatar
Does crankcase oil turn black right away, too soon?
Crankster is offline   Reply With Quote
Old 02-05-2018, 10:57 PM   #8
Bulligen
Bulligen's Avatar
John, we had a problem in which the pan gasket was interfering with the breather up front, I wonder If there could be a similar issue. What if you took a quart of oil out and ran it. Could it be possible that there is just too much oil in the pan?
Old 02-06-2018, 10:24 AM   #9
john in illinois
It does not use a lot of oil. seems like a 1/2 cup every 200 or so miles. I did not really keep track.
The oil does not turn black.
The vents and oil fill seems to be a good thing to check. I use 5 quarts of oil not counting filter. There was a lot of discussion about using 4 or 5 quarts. I am going to use 4 qts and see how that affects it.
I will check if there is something restricting the venting and I will address that.
Thanks for all your replies. I will be glad if I do not have to take it appart.
John
Old 02-06-2018, 12:33 PM   #10
flatjack9
flatjack9's Avatar
That's about a quart in 800 miles. Not great, but not the end of the world. Hopefully will get better with more miles.
Old 02-06-2018, 12:41 PM   #11
Jack E/NJ
Jack E/NJ's Avatar
>>>1/2 cup every 200 or so miles>>>
= 4 ozs
Jack E/NJ
Old 02-06-2018, 12:43 PM   #12
1942deluxe
1942deluxe's Avatar
What type of oil do you have in it? Rebuilt an engine in a 48 Ford some years back and put Motorcraft 10-30 in it. Rings weren't seating. Ended up using a mineral based oil for break in and after about 100 miles rings seated. Just a thought...
Old 02-06-2018, 12:48 PM   #13
Jack E/NJ
Jack E/NJ's Avatar
>>>The tailpipes have a coating of oil on the ends almost dripping out . The plugs have some oil fowling>>>1/2 cup every 200 or so miles>>>
Nope, I changed my mind. I don't think it's oil dripping out. Or some plug oil fowling. Maybe a little anti-freeze and water. But not oil. Do you a bit a white plumes in the exhaust? Jack E/NJ
Old 02-06-2018, 05:39 PM   #14
flatjack9
flatjack9's Avatar
= 4 ozs
Jack E/NJ
Misread the post, I thought 1 cup every 200 miles. At the rate listed, that's a quart every 1600 miles. Not to worry.
Old 02-06-2018, 07:22 PM   #15
lotsagas4u
What mineral based oil do you use for ring seating/breakin?
lotsagas4u is offline   Reply With Quote
Old 02-06-2018, 07:42 PM   #16
Kube
Kube's Avatar
John
John, Just to eliminate one possible issue: FIVE US QUARTS is proper. No additional oil for the filter.
Yes, there's been a lot of talk about how much is correct. What I hear is "blah, blah...".
I actually took the time to inspect the engineering drawings at the Ford Research Center and it is more than clear - it's FIVE US quarts.
Old 02-06-2018, 10:20 PM   #17
ursus
A retired engine rebuilder told me a secret. He employed used 10-30 crankcase oil for the start-up and initial run in of engines that he rebuilt and said that it allowed for a faster seating of the rings. This was soon changed out for clean new oil and his customers never knew of it.
ursus is offline   Reply With Quote
Old 02-07-2018, 12:14 AM   #18
Crankster
Crankster's Avatar
Will raw fuel turn oil black? I read that in the original post. I disagree with that idea. It sounds to me - if it truly is poor ring seat - that it needs to be driven on a highway trip. Don't be shy about it, full throttle acceleration several times, vary speed up and down with engine braking to wash cylinders down with oil and repeat. Get it good and hot. Try replacing a full quart in the crankcase with a quart of Marvel's before the highway run and run it in the fuel tank as well. 4 fl. oz per 10 US gallons.
Old 02-07-2018, 11:02 AM   #19
Pilot31135
Pilot31135's Avatar
I agree with Crankster, Drive it like a rental. It’s a Flathead it can take it.
Pilot31135 is offline   Reply With Quote
Old 02-08-2018, 08:22 AM   #20
Frank Miller
Frank Miller's Avatar
years ago we rebuilt a healy 3000 and the engine used a quart every couple of hundred miles.
one mechanic suggested taking it for a hard run up and down the pike. That fixed it.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
