Old 09-16-2016, 03:57 PM   #1
Al
Al's Avatar
Default cowl light lens retainer clip help
Hi:
Anyone have a pic of what the clips look like when holding the lens in place? I've not having much luck in getting these in to secure the glass. Or perhaps there is a trick you can share? Thought I'd ask before I break the clip or lens (or both).
Thanks
Al
Al is offline   Reply With Quote
Old 09-17-2016, 03:50 AM   #2
kevinmac/toledo
Default Re: cowl light lens retainer clip help
Originally Posted by Al View Post
Hi:
Thanks
Al
i dont have pic of clips ,but i will tell you i bought a set of original trim rings with the clips in them...noticed they were curved a little from inside to outside,maybe total curve of about 3/16 inch...they fit the trim ring real good...new clips are straight...dont figger how the straight ones would work now i discvered the curve...good luck ...hope this helps somebody.....kev
kevinmac/toledo is offline   Reply With Quote
Old 09-17-2016, 03:52 AM   #3
kevinmac/toledo
ps ...this is for the headlight rims...should be similar for cowl....kev
Old 09-17-2016, 06:47 AM   #4
C26Pinelake
Obviously make sure the curvier faces out. good luck, Wayne
C26Pinelake is offline   Reply With Quote
Old 09-17-2016, 09:55 AM   #5
Al
Al's Avatar
Thanks, just having difficulty figuring out how these do the job (orientation of the clip) not sure what side of the clip faces the outer edge of the rim.
Al
Old 09-17-2016, 10:03 AM   #6
Ken Anderson
Ken Anderson's Avatar
This video is for a 34 Ford BUT the clips are the same. See if this helps.
https://www.youtube.com/watch?v=O9VR9U5JCHA
Ken Anderson is offline   Reply With Quote
Old 09-17-2016, 10:22 AM   #7
Art Newland
Art Newland's Avatar
Hear is a pic of my headlight ring.
Art Newland is offline   Reply With Quote
