Old 06-19-2016, 05:53 AM   #1
mshmodela
mshmodela's Avatar
Default Late 31 fuel tank
It seems to me that a late 31 fuel tank (with the indented firewall) would not totally drain the tank since it appears that the valve is bit higher than the non-intented types.
Is that correct or not ?
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 06-19-2016, 06:13 AM   #2
MikeK
MikeK's Avatar
Default Re: Late 31 fuel tank
The tanks on both my late 31's drain completely. The pipe riveted to the bottom of the tank, in the same place as the valve in earlier tanks, goes straight out through the indent.
MikeK is offline   Reply With Quote
