Old 06-29-2017, 08:15 PM   #1
1930marie
1930marie's Avatar
Default Upholstery cracking
the seat back upholstery is drying out and cracking in several places. The cracks have not split open yet so I'm hoping somebody has a remedy? I think its Le Baron/B vinyl not leather. Is there something I can treat it with to soften it up and stop the drying out of the material? Thanks!
They know enough who know to learn.
1930marie is offline   Reply With Quote
Old 06-29-2017, 10:49 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Upholstery cracking
check with www.griots.com they have some great products! Been using for years. Out of Tacoma Wa. Vinyl and rubber dressing I use it on my tops and tires etc.
www.whidbeymodelaclub.com
Old 06-29-2017, 10:54 PM   #3
SeaSlugs
SeaSlugs's Avatar
http://www.homedepot.com/p/Rejuvenat...16CD/202675193
seems well liked...
boat people seem to like somethign called 303 protectant or use plain mink oil (i find it at menards near all the cleaners)
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 06-30-2017, 10:57 AM   #4
mike657894
mike657894's Avatar
Armour all works but need to be re applied often. vynal repair kits work surprising well. i repaired a boat seat that had a long rip in it on the front of the lower seat in a stress zone and the repair is still holding to my amazement because i still kneel on the drivers seat and it has been 5 years. Up close you see the repair but it blends well if youre not looking for it.
mike657894 is offline   Reply With Quote
Old 06-30-2017, 02:02 PM   #5
California Travieso
Send a message via Yahoo to California Travieso
Mike,
You're right. After you use it a couple of times if you don't reapply Armourall often, vinyl will become hard and brittle and crack. Once you use it you're committed.
David Serrano
California Travieso is offline   Reply With Quote
Old 06-30-2017, 03:34 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
Originally Posted by California Travieso View Post
Mike,
David Serrano
I was warned years ago to never use the stuff. Was told it makes the vinyl worse instead of better, so I never tried it.
Old 06-30-2017, 03:53 PM   #7
SeaSlugs
SeaSlugs's Avatar
same - for a dollar more use meguiers or mothers stuff....
Old 06-30-2017, 06:11 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
SS,
Is that the SAME Mothers' thet MAKES/SELLS PIES?
Bill Hungry
"THE ASSISTANT GURU OF STUFF"
Old 06-30-2017, 08:34 PM   #9
SeaSlugs
SeaSlugs's Avatar
Originally Posted by BILL WILLIAMSON View Post
SS,
Bill Hungry
well you could try to eat thier products... says exactly what to do on the back of the bottle if you do haha
Old 06-30-2017, 11:27 PM   #10
California Travieso
Tom & SeaSlugs,
I learned the hard way on the dashboard of one of my other cars.
David Serrano
Old 07-01-2017, 08:01 AM   #11
BILL WILLIAMSON
Back in the "PADDED DASH ERA", them Dudes would crack BAD! Companies made VERY THIN covers to glue in over them!!!
Armour-All was promoted as a "FIX" for it! Folks sprayed it on everything!!! It was MURDER when you got it on the rubber pedal pads!!! I "heard" someone sprayed his Vinyl seats, cut a short corner, door flew open & he SLID out on the BURNING HOT pavement!!! Some even used it to "WAX" their cars!!!---Then, along came S.T.P.----We had Words to clarify that "Acronym" but I fergot whut they were????
Bill W.
Old 07-01-2017, 08:10 AM   #12
eagle
eagle's Avatar
303 vinyl protector does wonders for vinyl that is aging. Use it on my boat seats. Doesn't get as slippery as Armorall. Armorall is bad stuff, alcohol in it.
Old 07-01-2017, 08:16 AM   #13
Keith True
Keith True's Avatar
I got my shop air compressor from a dealer because of Amour-all.The compressors were in a clean room next to the body shop.They decided to use the room for new car prep and used car recon and detailing.All of a sudden all paint work in the body shop turned into a disaster.Between the ceiling fans ,a lot of compressor use by the body shop,and a run of vinyl roof cleanups,the compressors sucked up a lot of the stuff.They didn't skimp on curing the problem,new compressors,all new black iron lines,all new hoses,anything remotely connected to the problem got replaced.I took the compressor apart and washed everything with some kind of chemical that removes silicone.It may have been MEK,I can't remember.I sloshed 5 gallons around in the 80 gallon tank for a while.I won't have any silicone sprays in my garage now.
Old 07-01-2017, 01:29 PM   #14
BILL WILLIAMSON
SILICONE is only good for BREAST IMPLANTS!
Bill Fondle
Old 07-01-2017, 07:22 PM   #15
1930marie
1930marie's Avatar
seems well liked...
Thanks for the excellent tip on the 303!
Bought Aerospace 303 protectant and applied to naugahyde roadster seat this morning and WOW what a difference! Upon application the material softened up and left a deep rich luster and softness to the upholstery! Thank you Seaslugs and to everyone who took time to respond with tips, I cut and paste all of them into my "A" files.
Old 07-01-2017, 07:30 PM   #16
1930marie
1930marie's Avatar
Wink Re: Upholstery cracking
Bill Fondle
Uncle Bill, how would you know about this? Where do "silicone breast implants" fit on my roadster (Marie)? (",)
Old 07-02-2017, 01:49 PM   #17
BILL WILLIAMSON
On the Dumb Blonde, in the RUMBLE Seat
Bill Grinning
Old 07-02-2017, 03:46 PM   #18
1930marie
1930marie's Avatar
Smile Re: Upholstery cracking
Bill Grinning
LOL's!! 😄
