09-23-2020, 05:51 PM | #1 |
Door striker plate screws on coupe
I want to replace the striker plate screws on a 30 coupe. My question is are the nuts on the screws captured? I don't want to find out the hard way.
All help is appreciated. |
09-24-2020, 04:40 AM | #2 |
Re: Door striker plate screws on coupe
I did re-adjust the striker plate on my '29 this summer, the wear allowed the door to become slightly ajar. Usually a right turn or maybe a hard bump would do it. Probably replace mine this winter.. the nut plate is secure in the door frame construction on mine (a May '29 build). I just loosened the screws, adjusted the fit/closure, and tightened. So far no problems, good luck.! kb
09-24-2020, 07:20 AM | #3 |
I replaced those screws on my 30 Coupe, don't remember why. IIRC, a movable threaded plate is captive behind the jamb. Replace one at a time to keep the same adjustmemt.
09-24-2020, 08:54 PM | #4 |
