Old 10-10-2012, 07:07 PM   #1
39 STD
39 STD's Avatar
Default Oil pump removal ?
Started to strip my 59a block down for a rebuild. Got to the oil pump. Removed the screen & pickup, the lock wire & pump bolt into the block. I assume it should drop out of the block.This thing won't move. Am I missing something or is there a trick to get it out. It'll be replaced but I don't want to break the pump housing off in the block.
God is great, beer is good -----People are crazy
39 STD is offline   Reply With Quote
Old 10-10-2012, 07:28 PM   #2
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: Oil pump removal ?
Here is a recent post on the same question.
http://www.fordbarn.com/forum/showthread.php?t=85654
John
Old 10-10-2012, 09:30 PM   #3
39 STD
39 STD's Avatar
Thanks. I did a search but nothing came up at the time.
Old 10-10-2012, 09:42 PM   #4
Binx
Here ya go:
https://fordbarn.com/forum/showthread.php?t=85654
Binx is offline   Reply With Quote
Old 10-10-2012, 10:19 PM   #5
Mike in AZ
Mike in AZ's Avatar
click on the links....they've already done the search....Mike
Mike in AZ is offline   Reply With Quote
