Old 10-29-2018, 11:31 AM   #1
12secvx
Default Oil pump shield modification questions
I was going through my box of model a oil pumps to choose which one I was going to rebuild. And found one that someone previously had modified the outer pump baffle/shield. Is this something anyone here has seen done before. If so are there any benefits to performing this modification or it is it hurting the function. Ben
File Type: jpg 5C91010B-3588-4120-93AE-35C486366542.jpg (52.1 KB, 36 views)
12secvx is offline   Reply With Quote
Old 10-29-2018, 01:08 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Oil pump shield modification questions
It hurts function, raises the minimum oil level that can be pumped
Old 10-30-2018, 10:34 AM   #3
Jim Brierley
Also more apt to 'aerate'. The shield is designed to force the pump to pick up oil from very low in the pan.
Jim Brierley is offline   Reply With Quote
Old 10-30-2018, 10:43 AM   #4
30 Closed Cab PU
Perhaps modified due to reoccurring sludge in the bottom of the oil pan? Poor maintenance or crappy oil back in the day..
30 Closed Cab PU is offline   Reply With Quote
Old 10-30-2018, 10:45 AM   #5
12secvx
Thanks for the replies guys. That is what my thoughts were as well but thought I would ask since the motor was running when disassembled.
Old 10-31-2018, 09:32 AM   #6
katy
katy's Avatar
Now that's a good trick.
Old 10-31-2018, 11:43 AM   #7
12secvx
Before I Disassembled it! Oops!
