Old 12-03-2014, 09:12 AM   #21
Binger
Binger's Avatar
Default Re: adapter t-5 transmission to model a moter
This isn't exactly Ford Barn friendly but you can see how it will work for a stock frame set up.
Binger is offline   Reply With Quote
Old 12-03-2014, 10:34 AM   #22
denis4x4
denis4x4's Avatar
You can use the stock A crossmember with a T-5. I fabricated the reinforcement piece, drilled holes and bolted it into place before cutting the cross member. You can use the stock radius rods by welding a 1/4" X 1-1/2" flat stock on the radius rod seam. You can just barely see it in the first photo. It will go much faster if you drill lightening holes in the flat stock! In the first shot, you can see how I used the stock brake set up to operate a master cylinder located under the passenger side floor board
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 12-03-2014, 05:43 PM   #23
dustyp489
Harleytoprock:
The plan is to make a trans mount and add a mount under that for the Radious rods . The kit that Auto resortration sold had the Rods hook to the bottom of the T-5. Serr's Kit does not call for a trans mount but I am not sure I like that, thats why I am adding one.
Skip
dustyp489 is offline   Reply With Quote
Old 12-03-2014, 06:16 PM   #24
harleytoprock
dusty, The Auto Restoration kit radius rod mount had the radius rod connection way low. This made the rear change angle and created poor driveshaft alignment . I guess you also have plans for beefier radius rods.
harleytoprock is offline   Reply With Quote
Old 12-03-2014, 10:31 PM   #25
100YVAT
were do you get the rear adapter (trany to a closed drive tube)
100YVAT is offline   Reply With Quote
Old 12-04-2014, 04:47 AM   #26
brokenspoke
crazydaddyo makes the adapter
brokenspoke is offline   Reply With Quote
Old 12-04-2014, 05:42 PM   #27
afuncar
model a trans gearing 1-3.12 2-1.85 3-1to1 S10 1-3.78 2-2.18 3-1.42 4-1to1 5-0.72 gm t5 #13-52-145 MINE CAME OUT OF 1986 V6 BLAZER.
afuncar is offline   Reply With Quote
Old 12-04-2014, 05:54 PM   #28
harleytoprock
If you look down this list, you'll find that many ratios were used on the T5.
http://www.britishv8.org/Articles/Bo...T5-ID-Tags.htm
Old 12-04-2014, 06:18 PM   #29
Logan
Logan's Avatar
I just assume all of us with right hand drive model a's are out of luck, unless we somehow come up with a rhd AA bell housing?
Cowtown A's
Logan is offline   Reply With Quote
Old 12-04-2014, 07:11 PM   #30
1931 flamingo
1931 flamingo's Avatar
Could always hook up a hyd clutch.......
Paul in CT
Old 12-22-2014, 07:41 PM   #31
T Pryor
I have a AA bell housing and a "new T-5". When using a AA bell housing I have question:
*Does the face of the AA bell housing have enough real-estate to just drill 4 mounting holes with no adapter plate?
* What clutch arm, clutch plate and clutch disc is recommended? I already have a new V-8 clutch from Snyders.
* I want to keep the torque tube arrangement. When shortening the Tube and Drive shaft.....How much is sectioned from both? Can I use a shaft coupling from these folks?
http://www.staffordmfg.com/Search.as...FWpk7AodBDQAKg
Do you have a tail piece adapter for this approach? Cost?
Hope you have a great Holiday, looking forward to your reply!
T Pryor is offline   Reply With Quote
Old 12-22-2014, 10:54 PM   #32
Pete
Pete's Avatar
Here is an adapter to get a T5 transmission to an A/B block that can be made with no machine tools. (lathe, mill)
All you need is a sawzall, a 3/8 drill motor and some rotary files.
All you need is a magnet base indicator to align it with the engine.
This uses a stock Chev V8 bell housing or Lakewood scatter shield, a
hydraulic clutch slave cylinder, stock Chev clutch and pressure plate and
a 12 lb CHEV aluminum flywheel.
The S10 T5 bolts right on. You can either use a Crazydaddyo adapter to torque tube or run an open driveline with center mounted radius rods.
The steel bracket on the 2 inch plate mounts a Chev gear drive starter on the right side.
And, no, I don't have any more info about it other than what is here but I know of 2 guys that made them from the shown pic.
Old 12-23-2014, 01:06 AM   #33
CarlG
CarlG's Avatar
Seems like I read somewhere that there was someone in NZ that was building a bell housing that would work with a T-5 or the RTS Tremec; RHD or LHD.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-23-2014, 12:09 PM   #34
T Pryor
Originally Posted by machine girl View Post
our kit uses the AA bell housing you don't need that offset disc.
How can I contact Machine Girl? Does she have a Webb site?
Old 12-23-2014, 02:54 PM   #35
hardtimes
hardtimes's Avatar
Go to top of page and click on 'community'. Click on 'members' and scroll down alphabetically to member Machine Girl. Click on name and get contact info...I think !!
hardtimes is offline   Reply With Quote
Old 12-23-2014, 03:45 PM   #36
CarlG
CarlG's Avatar
Google sez:
ModelAonly.NET
www.modelaonly.net/
ModelAonly.NET. Featured Items. Overdrive Transmission Kits; F100 Steering Conversions; Alternator Kits; Weber Carburetor Kits; Stainless Steel Timing ...
Alaskan A's
Old 12-23-2014, 08:46 PM   #37
mollydog
I'm just finishing my T-5 conversion. I used a belhousing from Graeme McNeill, Mac's Speedshop in New Zealand. Pricy but a good quality piece. It has the shaft to use the stock clutch and brake petals, Also has the shaft for the clutch throwout fork. I got an adapter from Speedway motors that goes on the T-5 input shaft and uses the stock A/B throwout bearing. Also I used a stock "A" flywheel and pressure plate. Speedway also has the 9" clutch disc with the correct spline for the T-5. The only mod I had to do was shorten the trans pilot shaft as it was to long. Speedway also has the correct pilot bearing for the T-5 to A or B flywheel.
Mollydog
mollydog is offline   Reply With Quote
