Old 04-15-2021, 04:14 PM   #1
BadBob
BadBob's Avatar
Default Head gasket question
I was told when I bought it that my 1930 A has an
After market high compression head but I don't
Know the brand. I want to buy a spare head gasket don't
Know what to buy. Any suggestions?
BadBob is offline   Reply With Quote
Old 04-15-2021, 04:33 PM   #2
Gene F
Gene F's Avatar
Default Re: Head gasket question
Hmmmm. I have had a high compression head on this my 3rd engine. I have never bought a spare gasket for one.
Does the head have any markings, or embossing on it?
Old 04-15-2021, 04:35 PM   #3
dennis lumbert
dennis lumbert's Avatar
I use the model B graphite head gasket from snyders with my 5.5 head from them also.Some prefer the copper gasket.
dennis lumbert is offline   Reply With Quote
Old 04-15-2021, 04:36 PM   #4
Mike Peters
Mike Peters's Avatar
https://www.fordbarn.com/forum/showt...on+head+gasket
Mike Peters is offline   Reply With Quote
Old 04-15-2021, 04:37 PM   #5
Synchro909
Synchro909's Avatar
Take the old gasket to a vendor so you can do a comparison. I bet a BEST graphite gasket (my choice) will do the job.
Old 04-15-2021, 04:38 PM   #6
GeneBob
High composition compression head gasket #A-6051-BA. This is a composition gasket that is the Model B pattern that works well (and is usually required) for a Model A high compression head.
GeneBob is offline   Reply With Quote
Old 04-16-2021, 04:15 AM   #7
Bruce of MN
Bruce of MN's Avatar
This worked very well with my 6:1 Head:
https://www.fordbarn.com/forum/showp...07&postcount=7
Old 04-20-2021, 09:36 AM   #8
jayvee34
jayvee34's Avatar
When I ordered my 5.5 head from Snyder I also ordered a copper head gasket.
A Snyder rep called and said not to use a copper head gasket and he changed my order
to a B-6051-XO head gasket, and said do not use any type of sealant.
jayvee34 is offline   Reply With Quote
Old 04-20-2021, 09:20 PM   #9
SteveE
Best brand. No copper spray needed.
SteveE is offline   Reply With Quote
Old 04-20-2021, 09:50 PM   #10
nkaminar
nkaminar's Avatar
Bad Bob, Model A heads require periodic re-tightening. Since you don't know when the last re-tightening was done, that should be top on your agenda. Follow the recommended sequence and torque to 55 foot-pounds in 10 foot-pound stages. Do this with the engine cold and repeat every 6 months. If you keep the head tight you probably won't need a head gasket.
I use the Best graphite gasket for the B engine with my Snyder 5.5 head. I used the copper spray gasket sealer.
Old 04-21-2021, 03:06 AM   #11
Rob Doe
Nice thread guys.
Rob Doe is offline   Reply With Quote
Old 04-21-2021, 12:31 PM   #12
Jim Brierley
Most vintage performance heads required a Model A gasket, as opposed to the B gasket. The important thing is for the gasket to fit the head, don't worry about fitting the block, it is totally flat.
