10-01-2017, 07:33 PM | #1 |
40 pickup V/8 pan
Oil leaking out the vent hole in the right front of pan. Is that vent hole necessary? Can the pan gasket be changed without pulling the engine. Thanks in advance for any information from the knowledgeable people on this forum. Nebrfox
10-05-2017, 10:03 AM | #2 |
Re: 40 pickup V/8 pan
Force the base deplete fitting and check whether there's any water, or smooth oil. Weight test your LU. Get new washers for the attachments. When you tilt the engine up, lube will spill out through the shifter seal if it's awful. Weight test will tell the story.
____________ buy essay to know the details |
10-05-2017, 03:31 PM | #3 | |
Charlie Stephens |
