Old 03-25-2021, 08:22 AM   #1
Lefthander1930
Lefthander1930's Avatar
Default Starter fuse Question ??
I see that some starters have fuses attach/on them. What is the reason ?
Lefthander1930 is offline   Reply With Quote
Old 03-25-2021, 08:35 AM   #2
Dean Lemoine
Dean Lemoine's Avatar
Default Re: Starter fuse Question ??
It doesn’t protect the starter. Originally, Model A’s had no fuses. The “starter” fuse you’re talking about should be a 30 Amp fuse protecting the rest of the car.
Dean Lemoine is offline   Reply With Quote
Old 03-25-2021, 09:47 AM   #3
Ivan in southeast va.
Ivan in southeast va.'s Avatar
I highly recommend the fuse assembly.
Ivan in southeast va. is offline   Reply With Quote
Old 03-25-2021, 10:07 AM   #4
Lefthander1930
I'm guessing one of the fuse will go to the starter, Where to connect the other end ?
Old 03-25-2021, 10:14 AM   #5
JayJay
When you buy the kit from the Model A parts houses it comes with hookup instructions. I put one in recently on my pickup, pretty simple but be sure you don't overtighten the mounting screws and strip the starter case. Here's a link to the instructions, courtesy of Brattons.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 03-25-2021, 10:32 AM   #6
rotorwrench
rotorwrench's Avatar
Since the battery power side is connected to the starter switch, that designates it as the main power terminal or buss terminal for the whole car. There is a history of early automobiles catching fire due to shorted wiring. Fuses and auto reset circuit breakers didn't start to show up until the V8 era that followed the model A in the 1930s.
Old 03-25-2021, 10:45 AM   #7
alexiskai
alexiskai's Avatar
Here's mine. The fuse backing mounts on the two starter switch screws on the engine side. The left-side fuse terminal attaches to the terminal on the starter switch (copper nut). Right-side fuse terminal attaches to the wire going to the terminal box.
(The red and yellow wires go to a permanently-attached connector that plugs into a battery tender.)
Old 03-25-2021, 11:44 AM   #8
jrelliott
jrelliott's Avatar
Highly recommend the fuse. As you know if you let the smoke out, it is hard to put it back. Protects the rest of the electrical wiring in the vehicle if you get a short. If you do not have a new electrical harness, you are asking for trouble. Cheap insurance from a fire in the wiring.
Old 03-25-2021, 12:13 PM   #9
Y-Blockhead
Y-Blockhead's Avatar
We have Model A Replacement Smoke... but the fuse is much cheaper.
Old 03-25-2021, 12:51 PM   #10
Charlie Stephens
I recommended a fuse for my friends Model A. He gave me a "yah I will think about it" response. As we were closing his garage I told him I thought I saw smoke. I finally convinced him I was serious and not just pushing the fuse suggestion. The terminal on the back of the ammeter was contacting the fuel tank and shorting out. Soon thereafter he installed a fuse.
Charlie Stephens
Old 03-25-2021, 12:56 PM   #11
burner31
burner31's Avatar
Put a zip tie on the fuse with the pigtail long enough to grab with your fingers, just a little tip for you.
Keith
Shawnee OK
'31 SW 160-B
Old 03-25-2021, 01:02 PM   #12
Y-Blockhead
I use a 30 amp circuit breaker. The rest of my circuits are fused.
Old 03-25-2021, 01:16 PM   #13
Model A Ron
Model A Ron's Avatar
Get a fuse....it helps keep the smoke in the wires
Model A Ron is offline   Reply With Quote
Old 03-25-2021, 06:17 PM   #14
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Or have a wooden stick, similar to a popsicle stick, in your door pocket, to pry it out.
Old 03-25-2021, 08:06 PM   #15
Stingray70
Stingray70's Avatar
I highly recommend the fuse. Be careful what size fuse you install though. When I bought my car, it had a 30a fuse installed. I had a short in a headlight connector which cooked the headlight harness and plug before the fuse blew. 20a is more appropriate for the wiring in these cars.
1930 Standard Coupe
Stingray70 is offline   Reply With Quote
Old 03-26-2021, 01:21 AM   #16
PotvinV8
PotvinV8's Avatar
Charlie Stephens
Same thing happened to me, except it was the modern-style ignition switch shorting against the tank. Big puff of smoke and car died. Blew the fuse and wiped out the wire, but that was an easy, if frustrating fix.
Another fan of installing a fuse to protect the harness with real world experience to boot...
PotvinV8 is offline   Reply With Quote
Old 03-26-2021, 09:06 AM   #17
Badpuppy
Cutout contacts stuck closed will drain the battery through the generator in "short" order. The fuse will prevent this.
