Old 04-28-2020, 01:36 PM   #1
chrs1961815
chrs1961815's Avatar
Default Early 28 Hood Splash Shield
My early 28 splash shield does not have any holes for mounting the felt. Did 28 not have any felt the shield. Should I still use it because of squeaks?
I am pretty sure it is original but I see the repros don't have spots for mounting the felt. Also the nuts on the shield appear to be 12-24 rather than 1/4-20 regularly. The standard hardware book says that 12-24 was used until April 28.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 04-29-2020, 10:29 AM   #2
d.j. moordigian
d.j. moordigian's Avatar
Default Re: Early 28 Hood Splash Shield
We need photos,...they do make a repop shield that doesn't look correct...
d.j. moordigian is offline   Reply With Quote
Old 04-29-2020, 11:38 AM   #3
Gary Karr
Gary Karr's Avatar
All 28/29 front aprons had two anti-squeak felt pads attached to the top of the outside with two semi-tubular rivets so if yours do not have the four holes, it is most likely a repop. Also to note, on the 28 style front aprons, I have found two sizes of "D" nuts used, 12-24 for the early sized hood shelf screws, and 1/4-20's for the later sized screws.
Gary Karr is offline   Reply With Quote
Old 04-30-2020, 01:04 PM   #4
Neil Wilson
Neil Wilson's Avatar
FYI - RGJS - page 13-3 - black painted 12-24 oval-headed screws used through July 1928. Page 13-4 - bead was only along the lower edge for 1928. Anti-squeak for all front shields indicated.
Snyder's does not show they have the 1928 front shield.
https://aafords.com/aa-chassis/aa-16000-fenders/#fss has more about the front splash shields.
[email protected] - email contact
https://aafords.com Ford Model AA Truck Club @ aafords.com
Neil Wilson is offline   Reply With Quote
