10-08-2013, 05:47 PM | #1 |
Radiator level question
OK, I give... where is the radiator water level supposed to be in normal operation?
I have no idea what the level is because it immediately spews enough water out to drop below the baffle. The overflow tube... should it be leaning forward or straight up? Engine is happy and does not seem to be running hot but I am loosing fluid all the time....and it marks its territory every night. (worse than any Harley I've owned) |
10-08-2013, 05:50 PM | #2 |
Re: Radiator level question
See if making the level just above the tubes keeps it from 'puking' water.
The tube position as you mentioned it is not that critical as long as it is tall enough. |
10-08-2013, 06:13 PM | #3 |
Each car is a little different. Add coolant to where you think it should be. Then add a bit more. Drive the car and allow the excess to spew out ( as you say). At this point the level should be where your car wants it. With the baffle in the way it is difficult to tell.
10-08-2013, 07:21 PM | #4 |
after doing post #3, you may be able to check and see the level when engine is hot at fast idle
10-09-2013, 01:23 AM | #5 |
Hi Mr. Wz,
FWIW: If the top of the overflow tube appears to be too low, thus causing excess lost of coolant, sometimes a properly sized, tight fitting length of rubber hose can be fitted over this overflow tube & allowed to extend in the upward direction; hence, with extended top end of the overflow tube positioned higher, coolant level cannot easily exit the former low top of the overflow tube & one can maintain a higher coolant level in the top of the radiator. Try it if you would like to experiment with same -- beats buying a new radiator. |
10-09-2013, 08:07 AM | #6 |
10-09-2013, 08:24 AM | #7 |
Had a gut feeling so I ran a test last night....and it failed.
Engine is stone cold. Filled the radiator to just below the top of the overflow tube. and watched it drip drip drip drip drip out of the bottom of the overflow tube. (top of tube is above water) I'm guessing that the overflow tube has a crack or hole in it ... probably as it passes through the header. grrrrrrr |
10-09-2013, 08:56 AM | #8 |
My coolant level falls too. They seek their own level. Block the bottom of the tube and fill the radiator to just below the top of the tube. Stick a piece of hose on the top of the tube and blow. No bubbles no crack.
10-09-2013, 11:02 AM | #9 | |
10-09-2013, 11:37 AM | #10 |
Sounds pretty clear that you have a leak. After you pull the radiator and take it to a shop for repair and reinstall (groan), you can use one of those long wooden coffee stir sticks as a dip stick to see what your water level is, at least how high the level is above the core. The dip stick can let you reach around the baffle and see what's going on in that zone between the baffle and the core.
As long as the level settles at some point above the core, you're ok. My new Brassworks radiator stays at ~3/4" (ignoring trig corrections for dipstick angle). Adding more is silly; it just pumps it out the first time I'm out on the highway. Steve |
10-09-2013, 08:00 PM | #11 | |
Going to try to solder it tonight. Got it drained, cleaned and dried but I got hungry. |
Thread Tools | |
Display Modes | |
