Old 05-23-2013, 08:17 PM   #1
JRHASZARD
JRHASZARD's Avatar
Default removing 39 PU steering column
I am removing the cab from my 39 pickup.Had to cut the bolts holding it to the frame. Now, how do I remove the steering column from the dash ? The bolts go downward and I can't see how to get to the heads of the two bolts. Perhaps removing the instruments would help. Does anyone have any suggestions ? Gracias Amigos !
JRHASZARD is offline   Reply With Quote
Old 05-23-2013, 09:11 PM   #2
deuce lover
deuce lover's Avatar
Default Re: removing 39 PU steering column
Might have twist off head bolts in there.Removing the speedometer might make it easier to get to.
deuce lover is offline   Reply With Quote
Old 05-23-2013, 10:06 PM   #3
ford3
most have twist off heads to stop theft, drill a small hole in the center of the bolt and use an easy out to remove the bolt, the square tapered easy outs work the best, you drive them in the hole to lock them in place while you unscrew them
ford3 is offline   Reply With Quote
Old 05-24-2013, 12:53 AM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
My '35's had one twist off, anti theft bolt (round head remains), and one hex head bolt holding the column to the dash. There was no way to drill and easy out that one bolt even with the speedometer removed. I used a pair of vise grip pliers to remove the round head bolt after applying penetrating oil and letting that soak in for a day.
John
Old 05-24-2013, 06:08 AM   #5
sunshine
sunshine's Avatar
R HAZARD I had one hexhead bolt and one headless I loosened the hexhead bolt. and cut the headless bolt with a sawsall. SUNSHINE
sunshine is offline   Reply With Quote
Old 05-24-2013, 06:56 AM   #6
JRHASZARD
JRHASZARD's Avatar
There are heads on the bolts. How do you get to them ? You have to be a contortionist or shrink yourself.
Old 05-24-2013, 06:42 PM   #7
39portlander
39portlander's Avatar
Oh those special "break-off" screws on the lock assembly, fun
I plan on re-installing my steering column when I get my bolts from Roy Nacewicz. R-91-11 for a bolt kit version for re-attachment. D-629-A for the steering gear assembly to frame. Take-er-slow, Scott
39portlander is offline   Reply With Quote
