Old 03-20-2013, 01:15 PM   #21
FlatheadTed
FlatheadTed's Avatar
Default Re: Cab to Frame Bolts 39 Pickup
Clutch driving plate springs .Or fuel tank ones sold by the vender's .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 03-20-2013, 06:53 PM   #22
37fordpickup
When I took the cab off my 37 pick up, the front bolts had the springs on top. The rear bolts had the springs underneath. I bought the entire cab bolt kit from Ray and he will also tell you what color the springs were when the truck was assembled. I almost done cutting and drilling the replacement wood out of some oak I had out in the shop. There were "farbic" spacers at each bolt, either between the front body or between the wood spacer and the frame.
37fordpickup is offline   Reply With Quote
Old 03-26-2013, 09:24 PM   #23
Clem Clement
Clem Clement's Avatar
I'm told the springs are topside.
Clem Clement is offline   Reply With Quote
Old 03-26-2013, 09:35 PM   #24
malpais
malpais's Avatar
Photos earlier in thread show some on top; some on bottom.
Don't mind learning from my mistakes. Just wish I didn't learn EVERYTHING from my mistakes..
malpais is offline   Reply With Quote
Old 03-27-2013, 07:28 AM   #25
Mart
Mart's Avatar
Re on top or on bottom: can't give a definitive answer, but I believe Ford fitted them on the bottom. My 41 pickup was as it left the factory, and all 4 corner ones were on the bottom. You couldn't really fit the rearmost ones on top as they would be inside the cab.
It is good practice to fit the bolt from the top and the nut on the bottom. If the nut comes loose and falls off, at least the bolt stays in situ as a locator and only a nut is required to make the repair.
While no-one can be certain, I would guess that any that are fitted with the nut on top may have been done after it left the factory.
Mart.
