Old 10-26-2020, 07:07 PM   #1
atch
atch's Avatar
Default 31 lower cowl patch panel recommendations
The ONLY rust in my 1931 two door sedan is the drivers lower cowl. Note: previous owner had cut off the bottom 6-8 inches of this cowl, so I don't have anything to even start with.
(the rear wheel wells were cut out; see my other post)
The only lower cowl patch panel I have found on line is Bert's. I've heard many good things about Bert's but have never purchased anything from them.
Has anyone used these?
I don't mind slicin' and dicin' but only if the bead contour is correct. Anyone know about the contour?
atch (Mike Atchley)
Columbia, Missouri
atch is offline   Reply With Quote
Old 10-26-2020, 08:34 PM   #2
aford193031
aford193031's Avatar
Default Re: 31 lower cowl patch panel recommendations
Contact Bert's, they are very knowledgeable. they can and will tell you if the patch panels will fit without modifications.
aford193031 is offline   Reply With Quote
Old 10-26-2020, 08:43 PM   #3
Bob C
Bill Stipe makes the best ones, ask the dealer whose they sell.
http://www.specialtymotorcams.com/de...nels-cowlpatch
Old 10-26-2020, 09:53 PM   #4
atch
atch's Avatar
I can/will do that; just wanted to hear from anyone who had actually used them.
I actually have a wish list of parts that I need and will be buying from them.
Thanx Bob. I had read numerous posts here and other places raving about Bill Stipe's panels but all my Googling only turned up his engine parts.
atch (Mike Atchley)
Columbia, Missouri
Old 10-27-2020, 02:49 AM   #5
john charlton
john charlton's Avatar
The replacement panels come complete as seen in the previous post . I have fitted several of these over the years I do not fit the complete panel as the front end where the cowl band hooks on etc etc is generally sound so I crop the new panel vertically just behind this area and MIG it in place a skim of bondo and job done . Replacing the complete patch is a much more complicated repair ,alignment etc etc .
John in Suffolk County England .
Old 10-27-2020, 05:02 AM   #6
jwmckenzie
I put a coupe of sets on in the past 5 years. They came from Snyders, so not sure if the same as Berts have. Every patch panel I have installed needs some work to get it to fit.
The one's I put in a Coupe ended up being a bit too long so had to shorten them up so they fit at the back and also along the front where the cowl band fits. As John said, the less of the original sheet metal you have to cut out the better.
Seems like there were two options for the panels, one that had the correct contours and one that was just stamped flat. Of course, the former is more $$$, but if you don't have any original metal, spend the extra bucks to get the contours.
As said earlier, ask Steve about the bead and quality and contours
jwmckenzie is online now   Reply With Quote
Old 10-27-2020, 11:17 AM   #7
Bob Bidonde
Bob Bidonde's Avatar
I do not believe there is a commercial reproduction patch panel on the planet that fits without some metal working. Go on You Tube and search for installations of patch panels in a Model "A." Eastman has some videos of panels going into Model "A" Fords.
It has been my experience that the rear fender well patch panels are the easiest to install. Cowl panels will require bumping and shrinking to fit properly.
Bob Bidonde
Old 10-27-2020, 11:58 AM   #8
Oldbluoval
Oldbluoval's Avatar
Those made by Stipe are the easiest and best imho
Old 10-27-2020, 06:07 PM   #9
noyo55
Ditto for the Stipe panels !!! Very close
noyo55 is offline   Reply With Quote
Old 10-28-2020, 06:38 PM   #10
SteveB31
SteveB31's Avatar
Two very different 1930-1931 cowl,patch panels are currently being made. The cheap flat ones, and the good stipe ones. We only sell the good stipe ones, since the cheap ones are flat and not good in any way. The stipe ones are curved like the cowl, and work well.
Part # A-70018 at modelastore.com
Steve @ Bert’s
SteveB31 is offline   Reply With Quote
Old 10-28-2020, 08:07 PM   #11
atch
atch's Avatar
Thanx everyone for your time, expertise, and input.
I'll be ordering the Stipe panels.
atch (Mike Atchley)
Columbia, Missouri
