08-26-2019, 04:59 PM | #1 |
B head sample.
This is the first B head at my new iron foundry. The last foundry didn't have quality control so they had to go. Winfields, Thomas, and blocks are all slated to be cast.
Tod |
08-26-2019, 05:20 PM | #2 |
Re: B head sample.
Looking good Tod. What will be the standard compression ratio? will spark plugs be tapped/sizes? and finally, cost?
08-26-2019, 09:20 PM | #3 |
Re: B head sample.
Tod, excellent. Looks like you really nailed the crows foot combustion chamber.
08-27-2019, 02:18 AM | #4 |
Re: B head sample.
Very nice
08-30-2019, 12:40 PM | #5 |
Re: B head sample.
I picked this head up from the foundry today. It is very nice, especially for the first sample. They mentioned being very interested in sampling an engine block asap. I have quite a few Winfield heads and iron Thomas heads to make as well.
Tod |
08-30-2019, 06:23 PM | #6 |
Re: B head sample.
09-02-2019, 11:37 AM | #7 |
Re: B head sample.
got lucky on the bottom to
09-05-2019, 11:02 PM | #8 |
Re: B head sample.
I’m also ready when you get into production. I see that you cast. ‘C” into it. Since it’s higher compression might be more appropriate if it was “C+” ?h
09-05-2019, 11:32 PM | #9 |
Re: B head sample.
09-06-2019, 11:09 AM | #10 |
Re: B head sample.
That's a good thought, Charley !!!
09-07-2019, 05:02 PM | #11 |
Re: B head sample.
Just joking about the C+ guys. Don’t take your selves so seriously !!
10-01-2019, 04:47 AM | #12 |
Re: B head sample.
Just checking in for a little progress report.
Thanks |
10-01-2019, 10:41 AM | #13 |
Re: B head sample.
I was wondering how things were going. I was in for a B head, not sure now. whats stalling me out is how hard it is to get a water pump for a reasonable price for the B. should make a true B head that takes an A waterpump
10-01-2019, 11:47 AM | #14 | |
Re: B head sample.
Charlie Stephens Last edited by Charlie Stephens; 10-01-2019 at 11:54 AM. |
10-01-2019, 07:16 PM | #15 |
Re: B head sample.
More castings are ready to be made.
Tod |
10-02-2019, 05:51 AM | #16 |
Re: B head sample.
Tod, I noticed in a past thread that you have a Mazak in your shop. Just wondering if you use it to make this B head?
10-02-2019, 06:24 AM | #17 | |
Re: B head sample.
I'm not sure which Mazak you mean, but I am currently running all cylinder heads in my Toyoda Horizontal Machining Center. My new fixture design allows me to make heads with less set ups. I cut it from 3 to 2 set ups. In my new Mazak HMC I will be able to make blocks in 2 set ups as well. Tod |
10-02-2019, 07:03 AM | #18 |
Re: B head sample.
10-02-2019, 11:04 AM | #19 | |
Re: B head sample.
10-03-2019, 06:15 AM | #20 | |
Re: B head sample.
It should be no problem hitting the water passage. Tod |
