Old 04-02-2019, 11:30 AM   #1
svmsr1044
Default 47 Super Deluxe Dash Color
I know that the 47 Super Deluxe closed car dash color is gray metallic and the formula reference no. is 35861KM. My questions are these:
1.What should the gloss level be?? (gloss, semi gloss, matt)??
2.Can anyone supply a paint co. code for the correct color?? (Dupont, PPG, BASF, etc.)??
Thanks, Steve
svmsr1044 is online now   Reply With Quote
Old 04-03-2019, 06:57 AM   #2
Cecil/WV
Cecil/WV's Avatar
Default Re: 47 Super Deluxe Dash Color
This is what my '48 is!
PPG
35861K B Gray Met Dash/Chroma Base/interior
Cecil/WV is offline   Reply With Quote
Old 04-03-2019, 11:16 PM   #3
Drbrown
Drbrown's Avatar
This will bring some He-Haws ..... For my (late) '47 Super Deluxe Coupe, I had to repaint part of my dash board. I took a piece of my stock dash board to my local Lowe's store and found a perfect match .... a Spray Can of Rust-Oleum Gloss #7784 Charcoal Gray, bar code 200066 77848. Try it .... bring a trim piece to store, compare it, spend a couple bucks, and test it on a piece of primed metal. Be sure to apply at least two coats over light gray primer ( I did three) and let dry at least a day each between coats. I'm not blind yet and can't see any difference.
Drbrown is offline   Reply With Quote
Old 04-03-2019, 11:27 PM   #4
35fordtn
35fordtn's Avatar
I used a formula provided to me by cecil/wv for the 48 I am slowly messing with. I used DuPont Chromax base and tamco 2041 clear...
Old 04-04-2019, 11:07 AM   #5
34pickup
34pickup's Avatar
Not laughing...I used the same paint on mine.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 04-04-2019, 01:27 PM   #6
woodiewagon46
If I were you I would purchase the 1941/1948 Book offered by the V-8 Club. It answers your questions and more!
woodiewagon46 is offline   Reply With Quote
Old 04-05-2019, 01:01 PM   #7
1942deluxe
1942deluxe's Avatar
High jack the thread a little. I have a Deluxe and the needles on the gauges are silver. Most of the Super Deluxes are gold? But I've seen gauges with red hands (needles). Is the red for open cars or just a different vendor?
Old 04-05-2019, 04:05 PM   #8
FortyNiner
FortyNiner's Avatar
There were different gauge color schemes depending on the trim level. My 46 gauges are light colored and not red.
