07-15-2010, 03:11 PM | #1 |
Head puller For the model A
Who sells them? was it Gordys? Tried to google. I have PB blaster squirting out around Head gasket when hand cranking but its not popping loose all head nuts are backed off and engine is hanging from eye bolts screwed into spark plug holes it been hanging for a couple of days its over a hundred today today maybe it will pop loose.
Dennis in Kelsey ca |
07-15-2010, 04:38 PM | #2 |
Re: Head puller For the model A
Head Puller
Attaches using two of the spark plug holes and pulls the head upward while pushing on the top of 4 head studs. Can also be used for pulling the engine. USA Part NumberSpecificsPrice A-6010-PHead Puller 1928-31$85.00 / ea. A-6010-PSPuller Studs Only 1928-31$26.50 / pr. http://www.snydersantiqueauto.com/mo...parts-1?page=2 Snyders sells this one...it works great! Good Day! Dave in MN |
07-16-2010, 08:16 AM | #3 |
Thanks Dave. The Head Is off I got lucky.
08-07-2010, 10:46 PM | #4 |
I can't get the head on my A to pop. Is there anyone who would lend me a head puller and puller studs? Odds are I will nver need one again and I can't see spending over a $100 to pick one up to use once....
I will pay round trip shipping! And if I damage the puller I will buy you a new one... |
08-07-2010, 10:56 PM | #5 |
Bill & Dennis:
You can make head pullers using old spark plugs. Weld in a T handle made of 1/2 or 5/8 " bar stock into the plug with all porcelain broken out. Make two of them, screw them in firmly, they allows you to wiggle & manipulate the head and it come loose without two much trouble. David |
08-07-2010, 11:14 PM | #6 | |
Loosen the head nuts, attach to your engine lift and "lift" the car by the head, Spray around the studs and tap aound the head with a plastic hammer or a wooden baseball bat. leave over night and see what happens in the morning.
08-07-2010, 11:33 PM | #7 |
Thanks for the idea David...but before I take the time to try and make my own puller I would have to spend the C-note!
Really hoping someone has one sitting in the corner of there garage I can borrow.... Thanks fellas! |
08-08-2010, 02:33 AM | #8 |
How much does it cost to take two sparkplugs and knock porcelan out and install two eyebolts????? Did it over 50 years ago and it worked.
Paul in CT |
08-08-2010, 11:33 AM | #9 |
Take two cylinders to bottom dead center. Remove those spark plugs. Push rope into cylinder through spark plug holes untill those two cylinders are full of rope. Crank over engine and head will pop off.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
08-08-2010, 12:03 PM | #10 |
This works if the head isn't too stuck. I would suggest using the hand crank to avoid bending a rod just in case the head is really stuck.
08-08-2010, 12:30 PM | #11 |
if it is "REALLY STUCK" get you an old hatchet, drive it between the head and block-away from the valves, it this don't break the head loose, you will have a very nice fishing sinker
08-08-2010, 12:33 PM | #12 |
I am yet to have a head that would not come off. I purchased the Rainmaker Ron designed head puller about 7 years ago and it works great. I had some stubborn ones before that, but eventually they all came off. Rod
08-08-2010, 08:04 PM | #13 |
Time to use Gord's Easy Head Puller gbaverstock@bmts 100% lift history Gord. B
08-08-2010, 08:49 PM | #14 |
I and several members of the Fox Valley Region have successfully used "Gord's Easy Head Puller". It has worked on every head we asked it to pull.
08-09-2010, 08:19 AM | #15 | |
Your search for "gbaverstock@bmts" returned no results.
08-09-2010, 09:33 AM | #16 |
It appears to be an email address, not a website.
FYI, I've seen Gord demonstrate his head puller. Nice item that works without damage.
I know a lot of things; I just can't remember them all. 1928 CCPU 82-A 1931 Roadster 40-B Dlx (Canadian) |
08-10-2010, 04:26 AM | #17 |
If anyone wants to loan me a Gord's head puller shoot me a PM.... if one doesn't turn up I'll pull the trigger and buy one from Gord's....
I have my Snyders 5.5 head all ready to be installed!!! Thanks gents! |
08-10-2010, 10:41 AM | #18 |
Check out my write up on how easy it is to make your own!
http://www.fordbarn.com/forum/showthread.php?t=10340 ..
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC |
05-20-2021, 03:26 PM | #19 | |
I purchased one of these 10 years ago; works great! You still selling them? Reply to [email protected] |
05-20-2021, 04:15 PM | #20 | |
Had 2 old plugs, 2, 1/2" X 6" Bolts, bought the rest of the bolts and nuts from Lowes.
IN GOD WE TRUST - SEMPER FIDELIS John |
