Old 06-20-2021, 05:49 PM   #1
1962ThunderbirdRocket
1962ThunderbirdRocket's Avatar
Default 62 TBird Driver’s Seat move back farther
Good day.
Does anyone have experience moving the driver’s seat on a 1962 TBird back farther. Electric seat controls. I need more leg room.
Thank you for any assistance and knowledge.
Kris
1962ThunderbirdRocket is offline   Reply With Quote
Old 06-21-2021, 03:14 AM   #2
KULTULZ
KULTULZ's Avatar
Post Re: 62 TBird Driver’s Seat move back farther
You may find a quicker answer here - https://www.squarebirds.org/vbulletin/
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 06-21-2021, 07:14 AM   #3
Ford blue blood
Ford blue blood's Avatar
Default Re: 62 TBird Driver’s Seat move back farther
Pull the seat assembly out of the car, (4 bolts access from under), remove the lower cushion from the seat frame (4 bolts) and relocate the holes further to the rear. The seat skirt may cause an issue if you go more then 2". The picture is the seat frame unbolted from the seat cushion.
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 06-21-2021, 10:18 AM   #4
Thank you so much. I am checking this out. Registered with Square Birds. Really appreciate your help.
Old 06-21-2021, 10:21 AM   #5
Ford blue blood. Are the holes predrilled or do they need to be drilled. (Drilled in the track?)
Also I read somewhere that there are two nuts from the underside and two from the inside of the vehicle. Have you come across this?
Thank you!
Old 06-21-2021, 12:13 PM   #6
alt63bird
I beg to differ, but I'm blatantly biased on this one, especially since Squarebirds.org is primarily a '58-'60 site:
https://www.vintagethunderbirdclub.net/phpBB3/index.php
Ford at one time did have two sets of holes in the lower seat cushion to allow the seat assembly to be move back 2" or so. I had thought this was also the case on '61'-'63 bucket seats used in Galaxies, Falcons, 'Birds, etc., but it's been some time since I've had a spare set to check. Most people unbolt the seat cushion from the rack/slide mechanism, or remove the seat track from the floor, and add plates/holes/bolts to allow them to move the cushion/seat rearward, then reassemble. How one person did this for a '64 T-bird can be found here:
https://www.vintagethunderbirdclub.n...eg+room#p48970
There are other methods people have used that can be found by using the 'Search' function of the VTCI Forum with some keywords like 'leg room' but many of those point to issues with '55-'57 T-bird seat frames.
Alan H. Tast AIA, LEED AP BD+C
Technical Director/Past President-Editor-Publications Director, Vintage Thunderbird Club Int'l. (VTCI)
http://www.vintagethunderbirdclub.net
Author, "Thunderbird 1955-1966" & "Thunderbird 50 Years"
35+ year member, Crown Victoria Ass'n.
alt63bird is offline   Reply With Quote
Old 06-21-2021, 04:13 PM   #7
KULTULZ
KULTULZ's Avatar
Question Re: 62 TBird Driver’s Seat move back farther
No need to beg, plug your FORUM openly.
- WHY IS IT ... -
Old 06-22-2021, 07:08 AM   #8
Ford blue blood
The holes in the seat bracket are stock from the factory. Carefully measure back 1 - 2" and drill new holes. May have to weld a small extension to the front mounts. Also check for "extra holes in the seat cushion as Alan referred to.
Alan the 63 Bird seats I used in my Ranchero only have one set of holes in the seat cushion.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
Old 06-26-2021, 07:48 PM   #9
Thank you for the advice! Next week, I shall take it out. I’ll photograph the journey.
Old 07-12-2021, 07:33 PM   #10
This is what we did. Metal bars with two adjustments. 2.5" and 5" drilled for moving closer or farther if we want.
Attached seat to the bars and then to the body by different length grade 8 bolts from underneath the car.
The two factory studs were removed. The metal bars were threaded to accept the Grade 8 bolts.
The added legroom is wonderful.
Old 07-12-2021, 07:54 PM   #11
Can't figure out how to post the photos. Hmmm
Old 07-17-2021, 08:20 PM   #12
Gene F
Gene F's Avatar
Hmmm. I never thought about moving the track holes back, and using the factory holes in the floor. Good idea. My inseam is 38"...
