Old 10-26-2020, 07:44 AM   #1
oldmotorsguy
Default What color were OEM engine blocks in 1957?
I am considering buying a 1957 Ford Thunderbird, and noticed that the engine block, while great looking, was painted Chevy orange.
This doesn't seem right to me. What color were 312 cubic inch V8s in 1957? Ford Blue? Or was that too early for this color. Chevy orange can't be right...
oldmotorsguy is offline   Reply With Quote
Old 10-26-2020, 08:04 AM   #2
oldave57
Default Re: What color were OEM engine blocks in 1957?
The Ford engine color for 1957 was indeed a red/orange color (the official name was Ford engine red). The color of the Ford and Chevy engines for 1957 (probably from about 1954 thru 57, but I'm not sure of that) were both an red/orange color. The blue engine colors came with later model FE engines. If you like the 57 Tbird, don't let the engine color change your opinion of it. It is painted the correct color for 1957.
https://www.vintagethunderbirdclub.n...ic.php?t=10463
https://www.macsautoparts.com/ford_m...spray-can.html
Good Luck,
Dave
oldave57 is offline   Reply With Quote
Old 10-26-2020, 08:16 AM   #3
oldmotorsguy
oldave: thanks, good to know. It's a very nice car throughout. Chevy orange, who knew?
Old 10-26-2020, 11:35 AM   #4
dmsfrr
dmsfrr's Avatar
The Ford and Chevy red / orange engine colors are very similar, and with color variations between brands and mixing batches they can be difficult to tell apart.
I don't have a sample of the 'official' engine paint sold for 50's Y-Block engines. Just picked the one I liked from a local store spray can aisle for the two Birds I have. Duplicolor brand ceramic engine paint.
These aren't for judged car shows, I'm just building them close enough so I don't embarrass myself in front of the guys in the local T-Bird club. The engine color met with approval.
Color rendition in the photos varies with the lighting. The 4th photo has more daylight than the others.
My impression is the Ford red/orange engine color is slightly redder than the Chevy color. Photo 1, on the left.
At least it's the color I used...
dmsfrr is offline   Reply With Quote
Old 10-26-2020, 11:36 AM   #5
55blacktie
Ford red is correct, but it is not as orange as Chevy Orange. Ford Red can fade with age, looking more like Chevy Orange, but Ford Red is closer to Chrysler Red. If the paint is otherwise in good shape, I wouldn't be concerned. It is common, however, for the intake manifold paint to burn off due to the heat crossover for the automatic choke. Intake manifold gaskets/w smaller hole for the heat crossover are available, which prevent/reduce the possibility of burning off the paint. If you don't live in a cold climate, you can also block off the crossover on the manifold or at the heads. The Mummert aluminum intake manifold does not have the crossover, but the Blue Thunder does.
55blacktie is offline   Reply With Quote
Old 10-27-2020, 05:25 PM   #6
40 Deluxe
Good Luck,
Dave
No! No! No! Chevy orange is NOT the correct color for a '57 Ford engine!! Ford red is much redder than Chevy's orange.
Old 10-27-2020, 06:00 PM   #7
Ford Freak
Originally Posted by 40 deluxe View Post
no! No! No! Chevy orange is not the correct color for a '57 ford engine!! Ford red is much redder than chevy's orange.
x 2 !!!!!!!!!!
Ford Freak is online now   Reply With Quote
Old 10-28-2020, 05:22 AM   #8
KULTULZ
KULTULZ's Avatar
Post Re: What color were OEM engine blocks in 1957?
Not sure if 100% correct -
https://www.macsautoparts.com/ford_t...tabs-container
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 10-28-2020, 06:46 AM   #9
oldave57
X3 !!!!!!
When I replied to the OP that the 57 Ford and Chevy engines both had a red/orange color, I didn't mean that they were the SAME color, so I apologize to the OP if that was how it came across. In my defense, I did say that the Ford engine color was "Ford Red" and included a link to Macs engine paint, so hopefully it didn't create too much of a problem for his decision on the 57 T-Bird.
Old 10-28-2020, 10:35 AM   #10
estout81
Here's a picture of a '53 Ford engine taken at the eastern meet of the early V8 club in 2019.
estout81 is offline   Reply With Quote
