03-25-2016, 05:21 PM | #1 |
Gear Shift Lever Install
The gear shift lever on a '36 transmission popped out. And the transmission is stuck in gear. How do I reassemble it?
Kerry |
03-25-2016, 06:40 PM | #2 |
Re: Gear Shift Lever Install
It should slide right back in the way it came out. Beware of the little short pin in the threads of the shifter tower that may have fallen into the transmission. The pin goes through the shifter tower and locks into the groove on the ball of the shifter to keep the shifter from spinning around.
Chris |
03-25-2016, 06:58 PM | #3 | |
