Old 07-10-2020, 09:01 AM   #21
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Wet sand blasting??
Sounds like you were doing some 'vapor blasting' in Southington.
Old 07-10-2020, 01:55 PM   #22
frnkeore
frnkeore's Avatar
Originally Posted by 51 MERC-CT View Post
Glass bead is not aggressive enough (wrong media) for the removal of epoxy paint.
That, along with excessive air pressure is a recipe for disaster.
That may be but, it was the only thing available.
The aluminum I was working with was old traffic signs. They were free but, I didn't want the printed surface to show. It was in about '69 so, I assumed epoxy, rather than anything else available, in that day. But, my point is, that anything that peens a surface, will expand it, in relation to the opposing side and to be careful with thin sections of sheet metal.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 07-10-2020, 07:51 PM   #23
cmbrucew
cmbrucew's Avatar
Industrial painting companies used wet blasting when the AQMD squalked about dust.
After a while they went back to the dry sand.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
