Old 03-07-2020, 08:10 AM   #1
chiefdave
chiefdave's Avatar
Default Royal kingpins for '49
I need to replace the kingpins on my '49 sedan and am considering the Royal kit. Any input from anyone who has actually used them?
chiefdave is offline   Reply With Quote
Old 03-07-2020, 08:24 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Royal kingpins for '49
Have had them on my '51 Merc. for close to 20 years with no issues.
When first installed, most noticeable was that there seemed to be less steering effort needed.
Old 03-09-2020, 09:36 PM   #3
Rand
Rand's Avatar
Where did you get them?
Rand is offline   Reply With Quote
Old 03-09-2020, 10:01 PM   #4
GB SISSON
GB SISSON's Avatar
Are the royals a plain bushing or ball/roller bearings?
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 03-09-2020, 10:28 PM   #5
V8COOPMAN
V8COOPMAN's Avatar
They are tiny needle bearings. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-09-2020, 10:36 PM   #6
GB SISSON
GB SISSON's Avatar
Like on a U-joint? What about the load bearing thrust?
Old 03-09-2020, 10:58 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
This is a set for a Ford I-beam, but you should get the idea. DD
T5 W/TORQUE TUBE
Old 03-09-2020, 11:36 PM   #8
mobileparts
If you are going to do the upper outer and lower outer pin kits --- I have some nice
++ N.O.S. U.S.A. made ++ pin kits -- a nice matched set of four, if you would like!!!
Always best to simply call me --- Craig --- 516 - 485 - 1935 .... New York....
mobileparts is offline   Reply With Quote
Old 03-10-2020, 04:14 AM   #9
flatheadmurre
flatheadmurre's Avatar
The thing with needle/roller bearings is they are designed to move continuesly( thats the reason you have an angle in a driveshaft u-joint).
If they are at rest going straight forward for a long period you get galling...
Heard all kinds of reviews from great to fast failure about needle bearings in kingpins.
That said...if i was to reinvent the bushing for less friction i would go with a coated bushing.
Old 03-10-2020, 08:04 AM   #10
JSeery
JSeery's Avatar
I have not used the needle bearing king pins, but have sure read a lot of negative reviews from the people who have. Might want to research it a bit.
Old 03-10-2020, 09:15 PM   #11
Tinker
Tinker's Avatar
I agree with you jseery. I'm sure they roll right off the bat better. More parts more issues. But I have no experience with them. Keep it simple. Lot more opportunity for failure.
Old 03-10-2020, 10:51 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
And not to mention how costly they are....$419.99 at Speedy Bills for this '37-'41 Ford set. DD
T5 W/TORQUE TUBE
Old 03-10-2020, 11:13 PM   #13
Tinker
Tinker's Avatar
Seems unnecessary.
Old 03-11-2020, 07:42 AM   #14
flatford8
flatford8's Avatar
I got my kit at Shoebox-Central and install went well. Be sure to grease the thrust bearings with a pin-type grease fitting......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
flatford8 is online now   Reply With Quote
