Old 07-03-2021, 05:13 PM   #1
samsonized
Default 1936 flathead operating temp
i have a newly purchased 34 cabriolet that runs great what is normal operating temps for a flathead and what is max operating temps so as not to cause damage it has an aftermarket mechanical gauge that measures about 205 with the sender in the left head
samsonized is offline   Reply With Quote
Old 07-03-2021, 10:24 PM   #2
flatjack9
flatjack9's Avatar
Default Re: 1936 flathead operating temp
As long as it doesn't boil, you are OK. Mine typically runs around 185. A hot engine is a more efficient engine.
Old 07-04-2021, 12:23 PM   #3
JayChicago
JayChicago's Avatar
Would suggest checking actual temp. Bought a car once with aftermarket under-dash gauge and sweated all the way home cuz gauge was reading 220. Then found that actual temp was only 195.
You can get an infrared thermometer gun for about $20. Handy tool to have.
JayChicago is offline   Reply With Quote
Old 07-04-2021, 12:51 PM   #4
samsonized
good point
Old 07-04-2021, 01:48 PM   #5
HD Rider
I checked my mechanical gauge for accuracy in a pot of boiling water on the stove.
HD Rider is offline   Reply With Quote
Old 07-04-2021, 02:48 PM   #6
Rudolph
Rudolph's Avatar
I have Toyota Starlet thermostats in my motor and I reckon it actually made it run cooler
Rudolph is offline   Reply With Quote
