Old 01-18-2020, 09:49 AM   #1
whizzernick
whizzernick's Avatar
Default 1934 steering gear fluid
I am looking for steering gear fluid that does not leak for a 34 4door I am now working on.
whizzernick is offline   Reply With Quote
Old 01-18-2020, 09:56 AM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: 1934 steering gear fluid
I use John Deere Corn Head Grease . . . is almost like a thick out and it is wonderful in our early steering boxes! If you want a picture of the 'tube' - can take one when I'm out in my shop later on today.
Old 01-18-2020, 10:25 AM   #3
JSeery
JSeery's Avatar
It is thick except when it is under pressure, as between the gear surfaces.
Old 01-18-2020, 10:36 AM   #4
whizzernick
thanks --- yes --- send [email protected]
Old 01-18-2020, 11:54 AM   #5
BlueNotes
Here's a pic of the JD Corn Head grease
BlueNotes is online now   Reply With Quote
Old 01-18-2020, 02:27 PM   #6
1931 flamingo
1931 flamingo's Avatar
PennRite steering box lube..........NO leakee.
Paul in CT
Old 01-18-2020, 02:30 PM   #7
Anteek29
Anteek29's Avatar
JD Corn Head grease is what I use in my Model A steering box...no leak.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 01-18-2020, 03:10 PM   #8
whizzernick
just ordered Thanks all
Old 01-18-2020, 03:21 PM   #9
bobH
PennRite
bobH is offline   Reply With Quote
Old 01-18-2020, 04:17 PM   #10
1952henry
1952henry's Avatar
super S cotton picker spindle grease available at tractor supply co. 00 grease same as Penrite but half the price or less...$5.29/quart. Lithium based like Penrite.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 01-19-2020, 07:07 AM   #11
richard crow
fix the leak
richard crow is offline   Reply With Quote
Old 01-19-2020, 08:50 AM   #12
Terry,OH
Terry,OH's Avatar
What is embossed on the fill plug?
If you want the steering box to not leak have a modern seal installed in the sector housing and solder the tube that is in the steering shaft for the horn rod.
