Old 06-03-2021, 09:58 PM   #1
Rudolph
Rudolph's Avatar
Default Flywheel bolts
I am having a bit of trouble, I have run a FoMoCo 4 speed for a few years but I got a new clutch plate and the Springs hit the flywheel bolts by about 0.5,
Is there any other low profile bolts that would work with a flathead?
Rudolph is offline   Reply With Quote
Old 06-03-2021, 10:58 PM   #2
Rudolph
Rudolph's Avatar
Default Re: Flywheel bolts
Can I use the low profile ARP bolts with out the lock wire? I still need to keep that plate to hold the dowl pins in
Old 06-04-2021, 02:14 AM   #3
cas3
chuck em in a lathe and cut em off
Old 06-04-2021, 02:37 AM   #4
Rudolph
Rudolph's Avatar
I need to take about 3 mm off them, it would brake thrugh the lockwire holes and make a mess
Old 06-04-2021, 03:21 AM   #5
KiWinUS
KiWinUS's Avatar
Sounds like you may have clutch disc in backwards. The springs go out towards gearbox.
Old 06-04-2021, 03:59 AM   #6
flatford8
flatford8's Avatar
I think “Old Henry” had this issue. I don’t remember the solution. Maybe you can search his posts.......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 06-04-2021, 07:02 AM   #7
V8 Bob
V8 Bob's Avatar
I ran into a similar clearance issue with my new steel flywheel and aftermarket clutch. I was reluctant on grinding down flywheel bolts, so contacted ARP and bought bolts that have a reduced head height. Also removed the flathead flywheel locating dowel retainer that gained over .050". Just lightly stake the flywheel dowel holes to prevent any movement. Overall gain was over .100" that resulted in the extra spring clearance I needed.
Old 06-04-2021, 07:22 AM   #8
Tim Ayers
I used the ARP bolts as well. These special 12 point bolts have a low, but wide head. I used an aluminum flywheel and needed to use steel ring under them to prevent gauling issues. All fit under the clutch. They are nice bolts.
Tim Ayers is online now   Reply With Quote
Old 06-04-2021, 02:32 PM   #9
Rudolph
Rudolph's Avatar
I am using a mitsubishi clutch plate witch has a bigger marcel, the FoCoMo 4 speed has a fine spline input shaft
Old 06-04-2021, 02:33 PM   #10
Rudolph
Rudolph's Avatar
Is it ok to run the ARP bolts with no lock wire
File Type: jpg 885DBB2D-0017-4882-B805-4B1137299CC7.jpg (76.5 KB, 57 views)
Old 06-04-2021, 02:46 PM   #11
Brian
Brian's Avatar
I never run the lock wires, I just torque em up with loctite. Never yet had a flywheel come loose.
Old 06-04-2021, 03:01 PM   #12
Rudolph
Rudolph's Avatar
What do you reckon about leaving that steel plate out to and punching the flywheel to stop the locating pins falling out?
I had a flywheel come loose on a BMW and when it did it sheared off all 8 bolts anyway, funny thing is I was able to drive home and then I toched the throttle and the engine reved up so fast it clipped the valves on the piston and starter motor just turned the flywheel and not the engine.
Old 06-04-2021, 03:58 PM   #13
KiWinUS
KiWinUS's Avatar
What Brian said & yes punch flywheel to retain dowels
Old 06-04-2021, 08:45 PM   #14
Rudolph
Rudolph's Avatar
I will go and see if I can find a set after the long weekend
Old 06-07-2021, 06:47 PM   #15
Rudolph
Rudolph's Avatar
I got some low height ARP flywheel bolts witch look good they have a nice wide head witch is lower.
How meany lbs should I tighten them to? I am going to use some locktite and leave that steel plate out
Old 06-07-2021, 07:22 PM   #16
Brian
Brian's Avatar
65 ft/lbs...torque in three stages
Old 06-08-2021, 08:27 AM   #17
V8 Bob
V8 Bob's Avatar
The ARP bolts I bought were #P10AP.750-1. ARP torque specs are:
70 ft.lbs with ARP moly.
75 ft/lbs with 242 Loctite. (what I used)
85 ft.lbs with 30W oil.
Always follow ARP torque specs when using their bolts.
The flywheel bolt holes required a very slight chamfer to ensure full bolt head contact, per ARP.
