Old 02-05-2021, 01:06 PM   #1
whizzernick
whizzernick's Avatar
Default 1934 horn (help )
I am looking for the maker of this horn item that lets you use the original horn rod with U-joint steering ( not stock steering )
thanks for any help or directionAttachment 454886Attachment 454886
Attachment 454887
whizzernick is offline   Reply With Quote
Old 02-05-2021, 03:41 PM   #2
Andy
Default Re: 1934 horn (help )
Your links don’t work. I have added a contact ring to a 40 column to use the 40 button. The 32-39 wheels would require an insulated sleeve with a contact ring on the shaft plus the plunger.
Andy is offline   Reply With Quote
Old 02-07-2021, 10:48 AM   #3
whizzernick
can you draw me a picture . I just ordered a (Horn Wire Contact Brush *High Quality* Fits Willys MB Ford GPW CJ2A G503 (J4 ) Not sure how to connect to inside horn wire .
Thanks
