Old 07-21-2018, 11:37 AM   #21
J Franklin
J Franklin's Avatar
Default Re: model B motor in model A chassis
Originally Posted by fordrelic View Post
Are the model A and model B oil pumps the same?
No, but they will fit the same. The B shaft is undercut between the bushings to allow more oil flow. This can be done on a lathe to an A shaft.
Old 07-22-2018, 09:55 AM   #22
fordrelic
Anyone sure on Oil pump?
fordrelic is offline   Reply With Quote
Old 07-22-2018, 10:21 AM   #23
Bob C
J Franklin is correct, see November 1932 Service Bulletins.
Bob
Old 07-22-2018, 04:05 PM   #24
fordrelic
Thanks for information guys!
Old 10-20-2018, 06:16 PM   #25
fordrelic
Will a model A distributor work okay in the model B engine?
Old 10-20-2018, 06:36 PM   #26
Ian in Mississauga
No problem, that's what I'm running right now. You must make one change to your timing procedure: instead of setting the timing with the spark lever all way up(retard) put the lever 1/2 way down.
Ian in Mississauga is offline   Reply With Quote
Old 10-21-2018, 08:25 AM   #27
Ronnie Lawson
Ronnie Lawson's Avatar
My model a engine has model b crank and cam in it.
Ronnie Lawson is offline   Reply With Quote
Old 10-21-2018, 09:12 PM   #28
daren007
No.
daren007 is offline   Reply With Quote
Old 10-21-2018, 11:12 PM   #29
qmdv
qmdv's Avatar
Kong Jackson, Ed Winfield and myself in 1976. B engine, 39 transmission, model A rear end in a 29 roadster pickup. That is a Cook four port head with a one of a kind Kong ignition. the other side of the engine had two downdraft Winfield carbs.
Wish I still had it
qmdv is offline   Reply With Quote
Old 10-22-2018, 02:51 PM   #30
Jim Brierley
gmdy, I still have my Cook, last ran on the salt @ 167 MPH, on alky, with a turbo. Steve Serr of Miller hi-speed is in the process of producing a repro, improved Cook.
Old 10-23-2018, 06:25 PM   #31
fordrelic
Thanks for the info. guys. Probably won't have a Cook four port head.
Old 08-25-2020, 11:38 PM   #32
cfruoff
Wen I put a ModelB engine in my Model A, instead of cutting the model B oil pan, I enlarged the semicircular opening in the rear of a model A oil pan to fit into the cork seal channel in the Model B rear main cap. Worked fine.
Model B oil pumps shaft were cut down to a smaller diameter between the upper and lower pump bearings to improve oil flow in the pump body. Model A shafts were straight.
cfruoff is offline   Reply With Quote
Old 08-26-2020, 05:02 AM   #33
Juggler
Juggler's Avatar
Originally Posted by Chris Haynes View Post
The factory didn't put numbers on B engines.
IMG_1379
Juggler is offline   Reply With Quote
Old 08-26-2020, 03:08 PM   #34
john charlton
john charlton's Avatar
In England all "B" engines were serialled on the block pad . The law required that the engine itself must be serialled . AA trucks in England were built into 1936 . I had a 1935 AA with AA 4981139 stamped on the block . These engines had a "B" oil pan with no shroud attached . This is just to clarify if someone has a "B" engine which has a serial on the block ,they are a more robust engine than the Detroit engine with a thicker top deck and are not prone to cracks anymore than a "A" engine .In WW2 they were used in welders ,generators etc etc and some ran on kerosine with cast iron pistons and special exhaust heated inlet manifold . More astounding useless information !!!
John in same place same weather .
Old 08-26-2020, 04:47 PM   #35
john in illinois
john in illinois's Avatar
John,thanks for that interesting history. The Ford flatheads had the number on the transmission housing. Did they fit under the same rule? 32 on.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 08-27-2020, 05:41 AM   #36
john charlton
That is an interesting question .I do not know anybody with an English V8 but I will investigate and let you know.
Old 08-27-2020, 04:51 PM   #37
john in illinois
Thanks
John
Welcome each day
